Determine tongue weight
/ Determine tongue weight #21
good grief. how do you guys ever leave the house in the morning.
/ Determine tongue weight #22
<<snip>
1 foot to the jack on the right, 2 feet to the jack on the left. mulitiply the reading on the bathroom scale by 3 to get actual tongue weight. (if you use equal dimentions ie 1 foot right 1 foot right, then you mulitply by 2 but for 800-900lbs tongue weight your bathroom scale doesnt go to 400 lbs so your SOL have to use x3)
<snip>
So be sure to ESTIMATE (WAG) your total weight before you put it on your scale. For instance with a 12,000 lb load on my trailer I'd need a scale that goes to 300lb and at least 3 feet between the tongue and the scale and 1 foot to the other support. If I put it on a short support I'd break the scale.
/ Determine tongue weight #23
A second way is to estimate it based on "known quantities"... Open the gate of your truck and stack weight on it. Load it up to specific known amounts (300,400,500,600, etc)
Be careful if you do this, because my owner's manual says the tailgate is only rated for a few hundreds of pounds. Maybe 500 lbs? Dunno. But if you just start putting weight on it willy nilly, you may exceed whatever that rating is.
/ Determine tongue weight #24
I suppose i should have added that as you screw the tongue jack "down" you watch the scale.... and if it starts to max out, adjust your load before going further.
/ Determine tongue weight #25
Cant speak for every one else but i have a doorway in my house though which i walk. You?
/ Determine tongue weight #26
Good info, SCHISM... detailed process we can all work from too.
Thanks!
To make sure my physics / geometry days aren't too far from my brain... The weight on the scale is multiplied by the distance from the scale to the fixed support and then divided by the distance from the trailer tongue to the fixed support (3' / 1', or 2' / 1' from your example)... right?
/ Determine tongue weight #27
You'd think that if anyone was going to post that smart warning it would be me... The new Tundra's can pull a house off its foundation, but you can't put more than about 250 lbs on the gate when it's down!
/ Determine tongue weight #29
But before I walk through it, I measure it to make sure it is correct width, and then measure myself to make sure I will fit through it, then inspect it for any structural defects. I also oil the hinges every ten times I go through the door, and replace the knob biannually. I know some people prefer to let the dealer do the knob replacement, but I hate having to take the door in and being without it for a week.
/ Determine tongue weight #30
Are you out of your mind?!?!? You have to inspect the threshold to ensure it's not rotted and will support the weight! lol
/ Determine tongue weight #31
You forgot to ask your wife if it was ok....
/ Determine tongue weight #32
I replaced my thresholds with titanium some years ago, to avoid having to do this. I mean, really! Who wants to check their threshold EVERY time they go outside?
/ Determine tongue weight #33
Well who wants to go outside without checking the weather? Come on guys, if its not a perfect day outside, why bother?
/ Determine tongue weight #34
Oh GREAT! Now we are going to have to define a PERFECT day.
Am enjoying the discussion and the info.
Gerry
/ Determine tongue weight #35
Well we could revisit the question considering a goose neck trailer tongue weight, associated weight measuring schemes, loading and tie down techniques and risks. Then, we could decide which is the perfect trailer for hauling the perfect tractor :drink:eek:n a perfect day!
YANMAR VIO35-6A EXCAVATOR (A64279)
YANMAR VIO35-6A...
KENWORTH CAB AND HOOD (A65643)
KENWORTH CAB AND...
2021 JOHN DEERE 324L WHEEL LOADER (A65053)
2021 JOHN DEERE...
2018 FORD F-350 SUPER DUTY (A65643)
2018 FORD F-350...
2019 VERMEER LP573XDT LOW PROFILE VACUUM TRAILER (A63276)
2019 VERMEER...
2002 Mitsubishi Lancer Sedan (A64557)
2002 Mitsubishi...
