You hit then nail on the head.Fram oil filters are junk, I know this from personal experience.
everyone is allowed to believe what they want. I'll preface my post with that.
I've a fleet of just over 20 tractors.. and a few automobiles. My 98 dodge ram truck ran from 99 to the beginning of 2012 with fram, and then fram tough guard oil filters.. instaleld by me. when i got it nearly new.. it had a fram on it. I sold it to work earlier this year after I got another diesel... I gave them the one extra filter I had for it. it got an oil change using that filter recently. it will likely get a napa filter on it next as that is what work uses. truck has over 200K on it now. PS.. the truck also got walmart supertech 10w30 oil with no extra additives.. no stp.. etc. just 3000-3500mile oil changes with filter, including a fram air fitler.
my 2000 yukon had the same, with a couple exceptions. the first 2 ys it got dealer svc oil changes for free.. thus ac delco fitlers. after that it got supertech oil and fram fitlers.. then about a year ago the wife started taking it to the quick change palce.. and the filters are some unknown brand that looks like purolator if I had to guess.. after they overchargerd her i switched back to my own oil svc... am inthe process of trying a different oil right now.. not due to lube problems.. just some personal research on consumption based on miles in that 5.3 vortec. during this time I've switched to ac delco fitlers again. i can actually get them as cheap as fram...
of my tractors... with the exception of the 2 larger diesels.. they run cnh filters.. thought one of them came used of course.. with a fram.
all the others with spin on or common cartridge get fram. I have a couple rowcrops and laoder models I run a super tech as it is lower profile. and fits easier... most of those are getting walmart oil now.. though in the past I have used napa hpouse brand and traveler TSC brand.. whatever was cheaper. i do have a couple units using a special diesel oil, and one on a synthetic oil since I went thru the engine earlier this year.
I used to cut fitlers open to just look at them. after a couple years it became a chore... int he end.. not much difference.
only times I've had a lube issue on a tractor is when napa made a filter for the repalcement of the fram c159 fitler that is a floss media packed filter.. and napa decided to make it a peper pleat, and allis chalmers machines everywhere lost oil pressure
well.. the fram floss filter still worked fine..
I use napa oil fitlers for my power stroke diesels... havn't seen a fram replacement anyway.. thought the nap is cheap enough.
i think alot of people get worked up about ancedotal evidence.. still.. it's anyone's discretion to run any oil. expensive or not. I think some are too spendy.. won't hurt.. probably can't help.. but whatever..
soundguy
