Demountable trailer wheel/tire
/ Demountable trailer wheel/tire #1
Adiredneck
Gold Member
Upstate NY
2006 Kubota L3400DT, Kubota L5240
I have a factory built equipment trailer with dexter 6000lb axles on it. It has the mobile home type wheels on it, but the are real deal, not from a mobile home. The brake flanges are bolted on. I am replacing the two older tires with new 8-14.5 tires meant for equipment trailers, but I want a spare. I am going to keep one of the old tires and find a rim for it. Is there a difference in the rim width from the 7-14.5 vs the 8-14.5? Can I just get a rim from a MH axle and put proper tires on it?
/ Demountable trailer wheel/tire #2
I just picked up an old MH rim and can't see any difference between it and my trailer rims. Going to paint it up for a spare as well.
/ Demountable trailer wheel/tire #3
I'm not sure if the rims (m/h and utg) have different ratings. There is a 6 and 7 inch rim width though and the way I understand it, rim width plus one for correct tire size. If I'm remembering correctly, then your 8-14.5 tires should be on 7" rims.
/ Demountable trailer wheel/tire #4
We had a three axle trailer with 7-14.5 MH tires which we easily replaced with 8-14.5 bias LT tires on the same centerless rims
/ Demountable trailer wheel/tire #5
I would use a MH wheel. They are built to handle the weight of a MH. I've only seen MH dealers sell them as a tire/ wheel package and I've never seen a MH with 7-14.5 tires at any of the dealers around here.
/ Demountable trailer wheel/tire #6
MH tires are meant to be used seldom, and are kind of a throw-away item. We lost thru explosion, delamination etc tons of MH tires on utility and office trailers. When we went to LT, all problems completely stopped
/ Demountable trailer wheel/tire #7
Florida DOT will ticket a trailer with tires marked Mobile Home Use only. And yes, they are pretty easy to spot if you are looking.
/ Demountable trailer wheel/tire #8
That's what I was always told. Avoid mh tires and axles.
/ Demountable trailer wheel/tire #10
Hence the name "Crazy Al"?
We're not talking tires or axles, we are talking about using a steel wheel from a MH dealer as a spare with one of the used non MH tires the OP has. Do you have a reason why the steel wheel would go bad?
/ Demountable trailer wheel/tire #11
My apologies Dr. CrazyAl! You are right, the wheels would be fine. I guess I got a little lost cause to tell you the truth, I'm not sure I know what's being discussed here:
/ Demountable trailer wheel/tire #12
No problem. I just assumed the wheels were the same, if not I would like to know. I have a 11 ton 3 axle equipment trailer with these axles under them and the last thing I need is to find out that I may have sub par wheels that I'll want to replace.
I yanked one of the trailer tire/wheels off the trailer tonight. My dad had a couple of MH wheels laying around from an old homemade trailer. One of the old MH wheels still had a 7-14.5 tire on it, one had no tire. They are the same size wheels as the ones on my trailer. I could not tell any difference in the thickness of the metal. If anything, the finish might be in better shape than the ones on my trailer.
I considered swapping to 6-bolt drums & 15" tires, but I figured I would have $800.00 invested by the time I do all 4 wheels and I still would want a spare. Maybe in a couple of years..
2009 BMW Sedan (A61569)
2009 BMW Sedan...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
2005 C7500 20' Box Truck (A62613)
2005 C7500 20' Box...
BARRY HILL 20 GALLON ALLY WAY SPRAYER, 3PT (A63291)
BARRY HILL 20...
2021 Exmark Lazer Z 60in. Commercial Zero Turn Mower (A61572)
2021 Exmark Lazer...
2012 INTERNATIONAL 4300 4X2 26FT NON CDL BOX TRUCK (A59911)
2012 INTERNATIONAL...
