Is this a scam? tractor check
   / tractor check #11
Bob I really want a Perkins diesel, power steering, 6+2 trans, 2 stage 3 point.
Not sure if central KY too far but here are a couple of Perkins 135's:
Massey Ferguson 135 Diesel -- Power Steering
135 Massey Ferguson
Prices seem a little high to me but I am not an expert. They look like they are in real good condition and maybe if hours are low enough they are worth it. I will tell you they have been listed multiple times on CL. Not sure why. May be just not willing to deal any.
Jon
   / tractor check #12
135 Massey Ferguson
Jon
Both of those look good to me. I like that old iron! What's the interest in the 135 specifically Murph?
   / tractor check
Hey Martain, I like old stuff and nice lines the 135 is both. need someting in the 30 pto to run a 6 foot rotary. Hows welding been?
   / tractor check #14
I wanted to make sure you weren't getting rid of that DK40 already, was going to tell you that you could send it north! Been cleaning out the barn at the farm, so I got plenty of room for it!
As far as the welding, that's a long story for another time.
   / tractor check
Luv thr Dk Allready broke a exhaust pipe pulling scrap out of my woods, 70 bucks. You get time tell me about the welding story
   / tractor check #16
Need someone in Tennesse to checkout this Tractor sales place. I am told that the 135 was last produced in 1975 and this one is listed as a 1991 with 46 hours for 5500.00. Please help so I don't go down there for nuting. http://www.tractorhouse.com/listingsdetail/detail.aspx?OHID=7065805&
Murph
:confused:
Just by the picture Murf, it has all new sheet metal. New, hood, sides, front nose, fenders. Looks to have a bad PTO leak. The angle shows it has new gauges which explains the low hours. New Proofmeter/tachometer. 46 hours since all the work done maybe. Price is way out of the park. $3200 maybe.. if.. if the engine checked out. BTW the sheetmetal looks to be poorly fitted.
MasseyVW is correct about the age judging from the vertical mounted air filter.
They used that same air filter setup on both Perkins and Continentals.
The engineers where idiots when designing it. What the problem with that air filter is when you remove a heavily soiled filter, dirt would fall down into the chamber and would be sucked into the carb the next time it was started. Thus redesigning it and mounting it horizontally. Just a bit of history there. :D The birth year is anywhere from 1964 -67 Too many red flags, and too little info. My advice is to pass. -robert :thumbdown:
   / tractor check #17
135 Massey Ferguson
Jon
Jon that 135 in Kentucky is another window dressing job. New metal on it all around, poorly fitted. Price is way out of the park. Way out.:thumbdown:
   / tractor check
Thanks Robert for posting. I too thought there aint no way in hadies that machine has thatlow hours. If you here of a good one please PM me. Thanks
Murph
   / tractor check #19
Murph
Not too many diesel Perkins in this area. Plenty of Perkins and Continental gas 135's. Keep shaking those bushes. One will turn up to your liking. -robert
(INOP) CATERPILLAR 914G WHEEL LOADER (A52705)
(INOP) CATERPILLAR...
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
2019 CATERPILLAR D6T LGP HI-TRACK CRAWLER DOZER (A51246)
2019 CATERPILLAR...
2016 Ford F-550 Crew Cab Mason Dump Truck (A51692)
2016 Ford F-550...
CAT D6C Crawler Dozer (A47477)
CAT D6C Crawler...
