How do you put ballast in your tires?
   / How do you put ballast in your tires? #1
herringchoker
New Brunswick, Canada
Kubota B7800
I always hate to have to do this because it means I've had a flat tire. It happened again today, so I dug out my little setup I've used before. It's cheap and it works like a charm. It consists of a bucket, a drill pump and drill, 2 pieces of garden hose and a small hose clamp. I start with the tire flat, and the valve stem at close to 12:00. (This is about the same as 10:00 to 11:00 with full air.) I pump in 3 or 4 gallons, then reverse the drill for about 1 revolution and let the air (that the ballast has displaced) bleed out, then pump again. (Picture 4 shows the displaced air bubbling in the supply bucket.) When done, I flush the pump with clean water and then squirt a little oil in it and give it a few turns so it's ready for the next time.
   / How do you put ballast in your tires? #2
How interesting! Two things, One I never thought of reversing the drill pump for a bit to burp the air.. I bought the adaptor with the burp button. But I see you did not use an adaptor.. so $10 saved there.. item number two: Your drill pump seems to be much more substantial than the plastic POS I bought from Home Depot. Thanks for posting
James K0UA
   / How do you put ballast in your tires? #4
I call the tire repair brothers and they stop by with a pick up and all the bits and pcs. you would ever need to fix a tire. They will empty a tire, replace the inner tube and replace the fluid for around $100. They have been here a couple of times and make a PITA job look easy.
OK, call me lazy.
   / How do you put ballast in your tires? #5
Ayup you are lazy!! But that doesn't mean you are wrong or foolish. Letting people that have practised a job do it for a fair price usually saves money in the end but sometimes you have to tackle a project just to assure yourself that you have some skills in hand.
   / How do you put ballast in your tires? #6
James K0UA
That's basically the way the tire shop installed the RimGuard in my tires. They start with the tire at 11:00 o'clock and connect the fill hose. They use a pneumatic powered diaphram pump to transfer the liquid. After pumping in some liquid and building pressure in tire, they reverse the pump. Since this type of pump is a positive displacement pump, they keep pumping until they pull a bit of a vacuum on the tire. Then reverse the pump and transfer some more fluid, and repeat. Once the liquid level is above the valve stem, the pump pull the excess liquid out of the tire. Once the pump starts sucking air, they know they have the correct amount of liquid in the tire. They use a slick hose connector valve that allows them to remove the valve stem AFTER the hose is conneceted and reinstall the valve stem BEFORE disconnecting the hose so there is very little mess.
   / How do you put ballast in your tires? #7
James K0UA
I'm all for DOY, if not just to save a few bucks but to keep ourselves finely tuned mechanically.
I bought and used the adapter made for getting the air out while pumping. Well worth the $10. Trying to burp air out is fine the other way, but consider what may happen if drawn to much of a vacuum; the bead may break and then you may have 50 gallons of RimGuard running down your driveway. Just hanging a tire on a tractor with the rear end jacked off the ground could have the same effect, a broken bead. Then you really have a mess. Been there, done that. I don't understand why the tire is sitting on the block of wood. I would think that would make a difficult situation rolling it off without losing balance.
   / How do you put ballast in your tires? #8
:drink:
OK, call me lazy.
now thats my way of doing things take the easy way out:drink:
   / How do you put ballast in your tires? #9
James K0UA
yep.. i like his drill pump too.. the black pos one i have is.. well.. a pos too.. :)
   / How do you put ballast in your tires? #10
Yeah about the time I got all the fluid in, the "bearing" was getting stiff on the shaft. so at about 52 gallons it was struggling. I am not even sure it would work now. It was only $6 but it is definitely in the POS class of pumps.
James K0UA
LIMA MAC 60KW GENERATOR (A58216)
LIMA MAC 60KW...
2014 VOLVO VNL (A55745)
2014 VOLVO VNL...
LINDE H80D FORKLIFT (A58216)
LINDE H80D...
2009 TROXELL KILL TRAILER (A58214)
2009 TROXELL KILL...
2006 Dodge Ram 2500 4x4 Pickup Truck (Diesel), VIN # 3D7KS28C66G203434 (A57453)
2006 Dodge Ram...
1000 GALLON PROPANE TANK (A52708)
1000 GALLON...
