Jinma 354 3 point upgrade?
   / Jinma 354 3 point upgrade? #1
BellaRidgeFarm
Lake, Ohio
Jinma JM354
Does anyone know whether there is an aftermarket control unit for the rear 3 point hydraulics for a Jinma 354.
   / Jinma 354 3 point upgrade? #3
I think he means he wants down pressure, and maybe a hydraulic top link. Similar to the set up that 3rrl did to his. He wasn't very specific as to what his needs were.
Yes Bob, you are correct, I need to replace the factory control valve, but before doing it, if I can add a control for down pressure for an auger, I would like to find something that would work both. Sorry I wasn't clear about it in the first post.
   / Jinma 354 3 point upgrade? #5
Down pressure is usually an option for the auger not the 3pt hitch. The arms on a 3pt hitch float -- they are free to swing upward because they aren't attached to the lift cylinder. So they can't push down. Even if they could push down the geometry wouldn't be right for augering.
To get down pressure, you have to lock the lift arms in place and adjust the angle of the boom. A rigid triangle attached directly to the top mount of the 3pt hitch -- no top link -- and to the lift arms will lock the lift arms down. A hydraulic cylinder on the boom that adjusts the angle between the boom and the rigid triangle will be capable of creating down pressure. Note that virtually all of the force will be on the top mount. Note also that applying the lift cylinder on the 3pt hitch when the lift arms are locked is not a good idea!
This manual has some pictures that may be helpful:
http://www.bushhog.com/images/stories/documents/manuals/PostHoleDigger.pdf
2023 PJ 49FT Gooseneck Trailer - 35+5, Mega Ramps, 30,000 GVW, Electric Brakes (A52128)
2023 PJ 49FT...
2016 FORD F-150XL SINGLE CAB TRUCK (A51406)
2016 FORD F-150XL...
2013 ISUZU NPR STAKE BODY TRUCK (A51219)
2013 ISUZU NPR...
2012 SULLIVAN PALATEK AIR COMPRESSOR (A51222)
2012 SULLIVAN...
24in Tractor Backhoe Bucket BT4555 (A52128)
24in Tractor...
2022 FORD F-150 XL EXT CAB TRUCK (A51406)
2022 FORD F-150 XL...
