Hours on your PT - Who has the most
   / Hours on your PT - Who has the most #21
I bought my 422 in 2000 and it now has 1,793 hours on it and that is the Subaru engine. The last several years I have cut down on the hours since I got my 1845 which I use for most of my mowing. I mow about 6 acres plus about 1 1/2 miles of trails. I just use regular motor oil in both the engine and hydraulic system. Most of my use with the 422 is bucket work and mini hoe plus getting firewood. I used to average about 180 hours per year but now it is more like 140 per yr.
   / Hours on your PT - Who has the most #22
I figure I am putting around 60 to 100 hours a year. I have had 3 hour meters fail. Figure I will do the diesel purchase as a guage. 1.6 gallons per hour. 80 to 150 gallons purchased a year....
I think I got it in 2007 but would have to check, didn't use it nearly as much as I do now. was running under 50 hours the first 3 years as I was clearing land.. Now lots of mowing (24 man hours to mow our property if I do a detailed mow).
I figure I probably have around 600 hours max... I guess it isn't yet broke in from what diesel people tell me...
   / Hours on your PT - Who has the most #23
I actually got to put 25 minutes on it mowing tonight! We finally got some rain and the weeds popped up. :laughing:
   / Hours on your PT - Who has the most #24
Good to see your Robin still going strong after all those hours. I only average about 80 hrs/yr. Would be more except I use the F250 for snow plowing.
   / Hours on your PT - Who has the most #25
I run about 300 hours a year. That depends on amount of snow but normally I do about 280 in summer and 20 total in winter.
PJ
PJ
So where are you now? Sounds like about 2700 hours. Is this on the original engine?
   / Hours on your PT - Who has the most #27
At 1000 hours I put in a new engine (same type).
PJ
   / Hours on your PT - Who has the most #28
142 hours since January 2010
   / Hours on your PT - Who has the most #29
I have 170 hours since Dec 2010.
   / Hours on your PT - Who has the most #30
Hey Pajoube how many hours total do you have on your machine? I mean from when you bought it not just from the motor swap.
1998 FREIGHTLINER CST120 TANDEM AXLE SLEEPER TRUCK (A56129)
1998 FREIGHTLINER...
2012 NORAM POWER SYSTEMS 100KW GENERATOR (A53843)
2012 NORAM POWER...
2015 FREIGHTLINER M2 TANDEM AXLE 24FT FLATBED (A56129)
2015 FREIGHTLINER...
2015 Case TR340 Compact Track Loader Skid Steer (A55787)
2015 Case TR340...
New Holland TN75S 4WD 75HP Loader Utility Tractor (A55787)
New Holland TN75S...
Toro Zero Turn (A50324)
Toro Zero Turn...
