New Holland TN75DA
   / New Holland TN75DA #1
amack52
Ocala,Fl
Valtra A95/Kubota M9000/Deutz 7120/JD 970/MF 1155/Ford 3000/Case 580C/Allis Chalmers 180
Just joined the "club",having problems with a TN75DA,am looking for a service manual.A used one would be ok.Tractor was scanned at the dealer and trouble codes came up.If you start the tractor with it in gear it goes forward with the clutch pedal pushed in,does not matter what position the shuttle shifter is in,F N R,it still goes forward only.Any help would be appreciated,Thanks.
   / New Holland TN75DA #2
i ALSO NEED A MANUAL FOR THE SAME CALL ME IF YOU FOUND ONE
   / New Holland TN75DA #5
I bought mine off of e-bay for 299.00 + shipping. It took 5 months but I just kept checking. $500.00 is a ridiculous price for a new set of books not to mention the 25.00 they want to charge for the service manual cover...
Good Luck
   / New Holland TN75DA #6
DID YOU FIND WHAT YOUR PROBLEM IF SO WHAT WAS IT THANKS
   / New Holland TN75DA #7
Good Luck
Less than a day of labor @ shop rate.
You can buy the electrical and transmission sections separately and have 90% of all you will ever need.
Nobody is holding a gun to your head and forcing you to buy a $25 3 ring binder. Staples has them for quite a bit less.
   / New Holland TN75DA #8
No but the NH Blue 3 Ring Binder with the fancy numbers and pretty picture is COOL and looks sweet sitting on my shop shelf, Where I hope it stays for many years :cool2:
   / New Holland TN75DA #9
There you go. The price of admission to 'cool' is $25.
   / New Holland TN75DA #10
Walked out into the barn today and was greeted with a puddle under my tn75da. Looks like the seal on the hydraulic cylinder for steering is leaking. Can someone with the service manual provide me with the repair procedure to replace the seal?? I'd be most appreciative!
Thanks
2013 COACHMEN CATALINA TRAVEL TRAILER (A52472)
2013 COACHMEN...
2023 Trailerman Gooseneck (A50514)
2023 Trailerman...
TOW BEHIND FINISH MOWER (A50324)
TOW BEHIND FINISH...
2021 CATERPILLAR 246D3 WHEELED SKID STEER (A51242)
2021 CATERPILLAR...
2017 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2017 GENIE GTH-636...
(30) 9' Pipe Fence Posts (A50515)
(30) 9' Pipe Fence...
