IH 440 baler knotter issue...
/ IH 440 baler knotter issue... #1
aczlan
Good Morning
Northern Fingerlakes region of NY, USA
Kubota L3830GST, B7500HST, BX2660. Formerly: Case 480F LL, David Brown 880UE
We have a IH 440 baler that will tie on one side, but the other keeps twisting the twine wround the hook that ties the knot (never strips the knot off). It appears that the movable "finger" that should be flush with the lower section to hold the twine on is stuck in the "up" position.
Anyone have any experience with these balers? It came with the place and we would like ot sell it as our Hayliner 273 is a much better machine for us, but it would sell much better with 2 working knotters.
Thanks
Aaron Z
/ IH 440 baler knotter issue... #2
I Have a 430 baler which I think is a little smaller, I had a problem with mine and cleaned it leaving NO twine on the notter and oiling up everythine, cant tell you exactly what fixed it, but it started tieing after I cleaned it also it almost never misses a bale when it misses, I stop and clean the twine off the notters. Before I forget YOU MUST USE THE HEAVER TWINE 9000' ROOLS FROM TSC always works if you use the 16000' rools it will not cut it will tie and then pull back apart when it does not cut
I cleaned it out and we are using the 9000 rolls. Will try it again one of these days.
Aaron Z
2007 FORD EXPLORER (A60736)
2007 FORD EXPLORER...
ALLMAND MAXI-LITE II V-TWR (A60736)
ALLMAND MAXI-LITE...
2007 Blue Bird All American/All Canadian Bus (A61568)
2007 Blue Bird All...
832769 (A61166)
832769 (A61166)
1999 International 9200 Day Cab Truck, VIN # 2HSFMAHR0XC036739 (A57453)
1999 International...
FENCE PANELS (A58214)
