Bx25 split breaks?
/ Bx25 split breaks? #1
Smitrock5
Member
Zanesville Ohio
Cub Cadet 129
Ones the bx 25 have the two rear breaks, or one break for both rear wheels??
Sent from my iPhone using TractorByNet
/ Bx25 split breaks? #2
One brake for both rear wheels as do all of the BX model.
/ Bx25 split breaks? #3
One brake pedal (not split brakes) is pretty common for all sub compact tractors (SCUT). In fact I can't think of any that have split brakes.
The mahindra max 25 does but they are placed right above the gas pedal which I don't understand how or when u would use them....I understand how u could make the tractor pivot if the break were on the opposite side of the hst pedal but it's not...is there a reason they are all3 on the same side?
/ Bx25 split breaks? #5
The brakes are on the right for safety reasons. You brake with your right foot when driving your car so the use of your right foot is automatic. Braking with your left foot requires a thought process and is not instinctive. The slight delay in hitting the brake in an emergency can be dangerous.
Can u give me an example of when or how u would utilize the two breaks? If it were for a better turning radius while plowing or something, I get that...just don't know why they would have split breaks if u cant use them for Thai
/ Bx25 split breaks? #7
Unless you drive with two feet. :laughing:
/ Bx25 split breaks? #8
I can use the split brakes on my L5740 by using the cruise control to go forward. My son just uses his left foot on the brakes and some can apply the HST pedal and brakes at the same time.
Split brakes are used for sharper turns, to manage traction when one wheel is slipping in lieu of locking the rear differential and to steer in low traction situations such as snow plowing or back dragging with pressure on the FEL.
I personally rarely use mine, but as the result of another thread have tried all of the above.
/ Bx25 split breaks? #10
What is the purpose of having split breaks on the same side as the go pedal? It sure isn't safe to have both legs on one side.
As for the bx's, that brake is considered and called a parking break in the owners manual.
/ Bx25 split breaks? #11
You are 100% correct. I have split brakes on my B26, and they are on the same side as the HST pedal. The tractor does not have or even have the option of getting cruise control. If it did, then it would make sense. You could apply the cruise control and use the right or left brake to help in sharp turns. But with the B26 the split brake is completely useless. I have asked many Kubota salesmen the same question, and they all agree.
/ Bx25 split breaks? #12
really wouldn't work anyways if you had Kubota cruise on your B26.
On the B2620's when in cruise if you touch the brakes then the cruise disengages immediately / HST peddle goes into neutral ... your thought of using cruise then brakes to help steer wouldn't work as tractor would simply come to either a slower or crooked'r stop as hst peddle would jump into neutral when you tapped the brakes.
/ Bx25 split breaks? #13
On the L the cruise control only disengages when both pedals are depressed which makes it possible; surprised it is different on other models. Also on my L5740 -3, the brakes are closer to the center of the tractor than on the L5030 making it much easier to use them with the left leg.
/ Bx25 split breaks? #14
could be the same way on the B series as well.... I would have to test it out more to see if 1 pedel depress is different than 2 peddle on the cruise.
Myself I never use cruise because type of work I make is not conducive to cruise.
Cheers
/ Bx25 split breaks? #15
Cheers
Could be different than the GL, we have BX, GL and M, but I've never driven a B. We have a big yard and some fields, so we use cruise a lot.
/ Bx25 split breaks? #16
I personally see no need for split brakes on a hydro tractor. I have not used the brakes to assist me in turning a tractor since many-many years ago when I was plowing with a ford with two bottom plows at night. Run out to the end, and use the brakes to turn either left or right without slowing down or using the clutch. I was young then and had fast reflexes. On hydro tractors just lift the foot, make the turn and go again. Get a brake or clutch happy operator and it will not be long before someone will be splitting the tractor to replace either the clutch or brakes. Not a cheap or easy fix. A fix 99 percent of cut owners cannot do.
/ Bx25 split breaks? #17
I jumped to JD Green so I might get some flack on that, but I use my brakes all the time. My terrain almost insists of the use otherwise it is a lot of backing up. There are points on my property where the front wheels just don't get enough grip. Also I find them quite useful when you get the one wheel spinning, simply engage the brake on that side instead of locking the diff and still pushing through the turn and having to back up.
I agree that abuse could result in failure that could cause an excessive expense.
There has been a couple of experiences where the split brakes got me out of a bad situation.
/ Bx25 split breaks? #18
Yes you will.
You purchased an unsafe tractor(due to the brakes being on the left side), just as I have.......with the purchase of my Massey Ferguson:shocked:.
Might just be a good idea to park them beside each other and burn 'em both.:laughing::laughing:
/ Bx25 split breaks? #19
Don87 said:
Yes you will.
Funny part is that my brakes are on the left and gas on the right in my car too. LOL.
/ Bx25 split breaks? #20
I understand completely. I was using your post..............to respond to post number 5.
Would love to see him operate a dozer, skidder, or knuckle-boom loader............................or for that matter....................maybe we can give him a few hours on a JD backhoe, then hand him a Case.
The point being is that an automobile is not the same as a piece of equipment, and in my opinion........................if one doesn't have the capability to differentiate, maybe they shouldn't operate either one.
It was once argued to me on here, that the brake wasn't necessary on the hydro......................................On level ground it ain't, but try hooking to a 3 pt. implement in my yard once........and you will be glad to have the left foot brake.:thumbsup:
And you will 'cuss' the "Kubota Shuffle"!!!
2023 Kubota U48-5 Compact Excavator with Angle Blade and Hydraulic Thumb (A63118)
2023 Kubota U48-5...
BUYERS PREMIUM & PAYMENT TERMS (A59910)
BUYERS PREMIUM &...
2025 IRET13 Electric Tricycle (A64194)
2025 IRET13...
Timpte 720 All Aluminum 7000 Tilt Trailer (A63118)
Timpte 720 All...
2005 Peterbilt 379 Extended Day Cab (A62613)
2005 Peterbilt 379...
Midwestern Industries MEV Screen Model MEV 5X10-2 (A63118)
Midwestern...
