Box Scraper what size of box scraper and blade?
   / what size of box scraper and blade? #11
This is the one I ran on my 5040 boxblade.jpg 72in. and had to use 4wd sometimes just matters what your running it in.. It also has the rear blade on hinges weight is around #620(i think).
Foreman, you didn't have a problem with the 6' covering tracks? Did you find it difficult to get on the edge of something or in a tight place with the tractor and box blade being essentially identical width?
   / what size of box scraper and blade? #13
Just blade the driveway,set the pins were it stays put and it will run with rear tires. If I need to work ditches can use either my angle blade or front bucket on different situations.
2003 VOLVO VNL TANDEM AXLE SLEEPER TRUCK (A56138)
2003 VOLVO VNL...
2017 CASE IH 580 QUADTRAC ARTICULATING TRACTOR (A51247)
2017 CASE IH 580...
2019 TRAIL KING INDUSTRIES ADVANTAGE PLUS TRIAXLE RGN W/FLIP AXLE (A55745)
2019 TRAIL KING...
HYD QUICK ATTACH STUMP GRINDER (A52706)
HYD QUICK ATTACH...
2014 Toyota Corolla Sedan (A55853)
2014 Toyota...
2019 FORD F-550(INOPERABLE) (A55745)
2019 FORD...
