Kioti LK122 loader problems
/ Kioti LK122 loader problems #1
DennisZ
Santa Ynez, Ca
Kioti LK3054
I have a Kioti LK3054 with an KL122 FEL. The loader doesn't lift to the proper height. It raises about 5 feet off the ground and should go to 8 feet per the loader manual. I replaced the hydraulic/trans oil to the proper level in the sight glass. Still doesn't work properly. The rear hydraulics work fine. There is no linkage to adjust that I can see. The previous owner replaced the hydraulic pump around 2 years ago. There is a joy stick for the FEL and it has a relief valve. The hydraulic control block also has a relief valve. I don't hear the relief valves going off but I'm thinking this could be the problem. Anyone have similar problems? Any help that you can give would be appreciated.
/ Kioti LK122 loader problems #2
Install a hyd gage in the FEL valve, and take some pressure readings.
Check and see if the gage reads relief pressure when the lift arms are fully up.
Check and see if the gage reads relief pressure when the lift armsare fully up.
Good advice........... That's my next step........ Thanks
2021 CATERPILLAR 301.7CR EXCAVATOR (A62129)
2021 CATERPILLAR...
JOHN DEERE ROW MARKERS - SET OF STACK FOLD 12 ROW 30 INCH ROW MARKERS (A55315)
JOHN DEERE ROW...
2015 Ford F-150 Ext. Cab Pickup Truck (A61568)
2015 Ford F-150...
378893 (A61166)
378893 (A61166)
Year: 2017 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: 82349 Pla... (A59231)
Year: 2017 Make...
DEUTZ MARATHON...
