Comparison JD 3320 vs 4105
/ JD 3320 vs 4105 #1
BuzzardA91
Gold Member
West Granby CT
JD 4105. 375 Backhoe. 2005 Polaris Ranger
:confused2:
With the help of my last post ( lot great advise ), I have decided between the JD 3320 and 4105. I thought I was set on a 4105 ( more hp why not) but spoke with another mechanic who stated the 3320 has a much heavier frame then the 4105. Because of this the 3320 can take the 485 backhoe and the 4105 can only handle the 375 backhoe because of the stress on the frame. This got me doing a closer comparison. I originally dismissed the 3320 because I did not want the eHhdro in fear of tearing out wires underneath. I drove them both today and eHydro way nicer. The pedals take a lot of force under load to hold down with the Hydro. EHydro was effortless and less " jerky" when stopping in going back and forth. They are both about the same price. Same tranny from what I understand just controlled differently.
It comes down to the 4105 has metal hood and fenders and 12" wider width with same length and larger tires. But, it's only 90 pounds heavier, maybe there is something to that frame strength thing. The 3320 has same loader but can lift 200 more pounds but has less breakout force?.. The 485 backhoe is much larger and stronger then the 375.
Also the 3320 is a 120 inch engine and the 4105 is a 90 " with a turbo, I don't know if I like that. Turbo seems like more potential problems to me? Going from the 3320 to the 3520 brings 5 more hp but that tractor is also a turbo with the 90" engine. ($2,200 difference in price)
The mechanic also said the 3320 has less hp but will outperform the 4105 because of the powerband. But added PTO horsepower will suffer on 3320 vs 4105 (4-5 hp)
I would like to decide by Friday because all incentives change at end of month. Seems to me 3320 is winning out?
What do you all thing? Help......
Somebody else must have already gone through this?
/ JD 3320 vs 4105 #2
I always prefer a feature tractor (3320) over a economy (4105). I think the 3320 is a much nicer tractor overall, with plenty of power to boot. And yes, the 485 is much better than the 375.
I think it would make sense to price out a 3520 as well. Same frame and size, just a little more power. I think it's the 'sweet spot' in the 3x20's for price in terms of power.
/ JD 3320 vs 4105
About $2,200 more for 3520 but it has a smaller engine and a turbo. Not sure about that.
/ JD 3320 vs 4105 #4
I have the 3320's predecessor. The 4310. The only time I wished I had more hp is when mowing. Usually early in the season when the grass is thick. So, I just slow down. I'm using a 72" finish mower. Usually I mow in b range 3/4 of the speed. When it's thick, half. Never a problem with the loader or backhoe as far as power goes.
/ JD 3320 vs 4105 #5
Don't be worried about a turbo. Some make bigger deals out of it than they are. As long as you give a turbo a little more time to warm up and cool down, they will last as long as a standard engine. $2,200 seems steep though, would expect it to be quite a bit less than that.
/ JD 3320 vs 4105
Thank you. I'm getting the heavy duty bucket, what size, 72"? Also considering ordering the Skid Steer QA option.
/ JD 3320 vs 4105 #7
You want the 60". The 60" just covers the tracks and will deliver more power. The extra 12" will just hang off and you loose a lot of breakout force and digging ability.
I highly recommend the SSQA option, really opens the door for 3rd party accessories. Most will offer SSQA so there will be a lot less modification required, if any.
/ JD 3320 vs 4105 #8
My vote is on the 3320. Advantages:
485 backhoe
better loader capacity
smoother forward/reverse transitions
much more comfortable (nicer seat, 3 range tranny, dual brake pedals, tilt steering wheel, separate pedal for differential lock)
Foldable ROPS (can be useful in low clearance areas)
You will defiantly appreciate these features in the future, trust me, I have experience on both 3x20 and 3E tractors and liked the 3x20 way more than the 3E.
As far as your bucket, I would defiantly opt for the skid steer QA plate, it will make buying other attachments such as pallet forks much easier since skid steer attachments all use the same attachment system. Plus the SSQA plate Deere makes is much beefier than the pin style QA they offer standard with most compact tractors. Also I would look into either the 66" or 72" heavy duty bucket depending on how wide of a swath you want with loader work. With the SSQA you will likely get the foundry bucket (standard on the 110 TLB) which if i am right will come with the bolt on reversible cutting edge which will prevent wear to your bucket edge over time and many years tractoring. Plus I have found that the bolts on the cutting edge are great for moving trailers, just use the center bolt and pick up on the trailer hitch. The bolt will keep the trailer from sliding across the edge of the bucket and is very convenient in may instances. I use my Deere 317 skid steer to move horse trailers on occasion and love how i don't need to buy any new attachment to move trailers, all I need is my bucket. :thumbsup: Best of luck in your decision, looking forward to see which tractor you get. :thumbsup:
/ JD 3320 vs 4105
I guess JD does not offer the 72" HD SSQA bucket in this loader? Not sure why, weight? The offer it in the regular JD attach bucket, HD. Are the SSQA 72" HD buckets way heavier then JD 72" HD bucket with traditional JD hookup? I don't get that one.
Thank you for input.
/ JD 3320 vs 4105 #10
The 3320 is a pleasure to operate and is strong as an ox. The seat, padded floor, ehydro with the 300 cx loader was why I chose it after weighing all of the options you are looking at. Ad on some bucket hooks and a hydraulic top link and it's a slam dunk.
/ JD 3320 vs 4105 #11
How much can your loader lift?
/ JD 3320 vs 4105 #12
I started with a 2008 3320 O/S and last year sold it and bought another 3320 CAB. Truthfully mine is a giant yard toy for someone in second childhood, but for my applications lack of HP has never yet been a concern. If I did major PTO work or Ground Engaging maybe would feel different. A few times I would have liked more FEL lift, but the up charge to a 4x20 didn't seem worth the $$$. The 3 speed eHydro is great and especially so for FEL or Forks and MMM work. Load Match works. I have Cruise but really have never used the feature.
With bucket there are times when a bit of overhang is nice. As someone else said maybe 66" would be worth a look.
If starting with a fresh sheet SSQA would be good. I went with JDQA more because son had that and we could trade implements if needed.
The JD rear Quick Hitch thing looks good on paper, but often non JD stuff will not fit without modification so go into that with realistic expectations. Also to work properly probably need $65 set of bushings for each piece or change all the pins to CAT 2.
I have no experience with the 4105, but at the time of my choice, I knew for sure I did not want gears and after testing neither did I want Power Reverser or equivalent. If it fits your needs and $$$ I highly recommend 3320.
/ JD 3320 vs 4105
So CINDER ..... The max width is listed at 68+". So for general loader work and snow removal go with a 72" bucket? A 66" bucket wouldn't give any overhang but close to covering width. Which do I pick?
/ JD 3320 vs 4105 #15
You want one that just covers your wheels for earth moving and general purpose. If your only doing light duty, then go bigger. I thought that the 60" bucket was what covered the wheel base, but looks as though I'm mispoken.
Take a look at the picture of my 110 (72" HD bucket) and 3120. The picture doesn't really do it justice, but I definitely wouldn't want to try and use my old 3120 with my 110's bucket.
/ JD 3320 vs 4105 #16
Sorry for the potential confusion. I didn't go back and reread your other thread. I believe the 68" max is with R1 AG tires. They have a different two part rim which with one of the configurations produces the 68" Many of the posters on here use either R3 Turfs or the R4 Industrial tires, so my answer was based on those sizes. From memory max width for R3 / R4 is 59", so in theory with the standard bucket which has a nominal width of (I believe) 61" there is a tiny bit of overhang. I have a 61" Heavy Duty and a Materials 84" Bucket. In retrospect a 66" might have been a good choice for my purposes.
The 84" works relatively well for snow or light material and reasonably well for back dragging, but the bucket is so heavy itself that it is really no use for things like digging or dirt / rocks.
/ JD 3320 vs 4105
Thanks for checking that CINDER. going from Ags to R4's ( my choice ) cuts 9" in width? That sound right?
/ JD 3320 vs 4105 #18
I recently sold my 3320 as I traded to a 4520 cab. I had the larger R4's and the 72" bucket and that is exactly what I would order again. I also had a set of Artillian pallet forks which I have kept because they are so good. They now go with the 2720.
It's a great small utility tractor. I put 4" wheel spacers on mine and used the loader to it's max capacity which is very good at 1600# especially compared to other similar sized tractors. I would still get the 72" bucket. I didn't do a lot of digging with it but I moved a lot of material and the extra capacity was worth it.
Overall, I was, and remain, impressed with the 3320.
/ JD 3320 vs 4105
I'm bout ready to give up and buy a shovel and wheelbarrow. After yet ANOTHER conflicting report from a JD dealer I went on my own for my questions. JD corporate was ZERO help. We know the models better then who I spoke with.
I'm back to the 4105 if I don't just give up on whole thing out frustration, it shouldn't be this hard, and it is no longer fun. At the dealer today there was a 3320 with a broken backhoe, bolts and mounts. Mechanic said it was over worked and too heavy for frame of 3320. Totally opposite what other JD dealer said. They said 3320 was a far stronger frame then 4105, hence the bigger backhoe.
Here is what I found. The 4105 is considered a large framed CUT and the 3320 a medium framed. However, the rear axle on the 4105 is rated for 4000 pounds and the 3320 5,200 pounds. I think THAT is why the bigger hoe.
Also found on my own ground clearance on 3320 is 11" and the 4105 14.7". This will be important for me. 4105 also comes with way bigger tires.
I don't like the plastic on the 3320, I don't like all the electronic controls on 3320. I do like the bigger hoe and the smoother eHydro. I like the 12" wider width of 4105, don't like the jerkier transmission, afraid of the turbo, but do like the simplicity and the way more HP.
Confused on why the 4105 has a 10% reduced lift but 10% greater breakout force which I think is a more Important measurement.
Four dealers so far. One said don't sell or make the 4105 anymore. One said 4105 doesn't come with quick park loader hoe, cruise, SCV. All wrong according to brochure. Other dealer can have in a week.
I guess I'm on my own. I want simple but don't want to buy stupid. Maybe the 3320 with broken hoe is the only one ever to break but it is wearing on me.
/ JD 3320 vs 4105 #20
Any machine can be overworked, don't get too worried over one instance. As long as you treat ANY machine right, it will treat you right.
The 4105 is a physically larger machine than the 3320. Unless you need the extra HP for the PTO, otherwise per the specs, the two machines are very similar.
I love the plastic. As surprising as that may sound, it is extremely durable. It's a trade off, because I can take a baseball bat to the heavy duty plastic and it won't leave any sign of damage. Do the same thing on steel and you have a bunch of dents. Now, should you really wack something hard, and I mean REALLY hard, then the entire plastic piece is broke, but there's just a large dent in the steel. Either way, for it to look new, the entire piece will have to be replaced.
The 'goodies' of the 3320 are great! There's something to be said about simple. Trust me, I love driving my 1953 Farmall Cub around. There's nothing too the tractor. Three forward speeds, one reverse. No hydraulics whatsoever. That's fun for a little while, but if I had to work with something like that all day I'd be beat! All the comfort tractors are so much nicer than the old. Not saying that the 4105 is comparable to the Cub, it's not, but when you have a choice to run a 3320 or a 4105 all day, the 3320 would win out every time for me. May be a little smaller physically, and a little less HP. But the specs are relatively even and the 3320 is MUCH more comfortable. There's really no need to worry about the extra gizmos in terms of failure either, they are built to last.
As far as lift goes, there's funny things like that. The specs aren't perfect. In real world performance, I doubt you could tell the difference between the two.
I'd go talk to the dealers. Some of those things on the 4105 are optional, where they are standard on the 3320. Have them explain to you and show you the literature on where it says that.
My vote stays for the 3320, I think the one you saw was just a fluke.
