Posthole Digger do you have a yellow post hole digger with a round gearbox
   / do you have a yellow post hole digger with a round gearbox #11
Heres my World Agri Corp/International see if its this one.
Boone
Hi Boone, I was researching my own auger brand and after studying your images, am convinced that I have the same unit. I need to replace the auger's blades (those pieces of metal (2) that are attached with two screws each that help cut into the earth. Do you know of an online source where I can order these from? Also the spiral tip as well?
Thanks,
Joe
   / do you have a yellow post hole digger with a round gearbox #12
Joe, you could try your local Tractor Supply if you have one. They sell augers, and all of the parts, and most are universal. Its worth taking a look. :hypnodisk: The augers run about $120 new, and the parts are much cheaper. This is mine that I bought there, and the PHD is made by Speeco, and rebranded as Country Line for TSC, but the auger is made independently.
   / do you have a yellow post hole digger with a round gearbox #13
Thanks,
Joe
Welcome to TBN ! Try like Mitch said also PM sent.
Boone
   / do you have a yellow post hole digger with a round gearbox #14
Better pic of auger tip.
Boone
   / do you have a yellow post hole digger with a round gearbox #15
Mine was kind of an off yellow, almost very pale pumpkin color when I got it.
It is green and yellow now.............
Turned out to be an old Speeco, not sure what model.
I agree, maybe you need a new gear box and modify arm to attach to it.
Or for very little more money, a whole new one......
Good luck
Maybe this will work
I finally got the pics on here. if you notice the pto shaft is yellowish and it is yellow under the scratches, I've never seen one mount with a clamp like this.
   / do you have a yellow post hole digger with a round gearbox #18
Your PHD is an old " Servis" thats when they were built in Dallas,Texas.
Since then they were or married with"Rhino". Servis-Rhino .
Boone
Thanks Bullbreaker I'll have to see if I can get parts now. I new someone on here would Know.
   / do you have a yellow post hole digger with a round gearbox #20
If none of TBN sponsers have just that part try calling these folks they have helped me in past DN Equipment
Good Hunting-! :thumbsup:
Boone
2022 JOHN DEERE 330G SKID STEER (A52705)
2022 JOHN DEERE...
2007 Bomag BW120AD-4 Tandem Vibratory Smooth Drum Roller (A52377)
2007 Bomag...
Pull-Behind Reel Mower Tractor Attachment (A55851)
Pull-Behind Reel...
2015 Ford F550 Bucket Truck - Versalift VST47 Boom - Powerstroke Diesel - Automatic - 4X4 (A55302)
2015 Ford F550...
2014 Ford F-150 Ext. Cab Pickup Truck (A53422)
2014 Ford F-150...
