Vermeer 505M belts
/ Vermeer 505M belts #1
jltrent
Western VIrginia
Kubota
I have a couple of belts on my Vermeer 505M round baler that the alligator splices need replacing as the belts are torn at them. Will it be okay to cut a couple inches off the belts and put new ones in? Should I take all the belts out and re-size all a like? Thanks for any help.
/ Vermeer 505M belts #2
You shouldn't need to take off a couple of inches. If you pull all of the hooks out and cut it square along the holes, you can probably get by with about one-half inch or less per end. I'm kinda lazy and a tightwad, too, so I'd just do the ones you need to do if you can get by without cutting off too much. There's probably more difference than that in them by now, anyway.
/ Vermeer 505M belts #3
It's best to pull them all and cut them to the same length and resplice them all.
Use the shortest belt as your guide,use a sharp stanly knife and cut them square to the length using a carpentry square as a guide to cut along.
A couple inches shorter belts won't affect the bale dia to much, but using a shorter belt than the others will put undue strain on the shorter belt(s) splice and it might fail in short order.
Anyway,that is my experience.
Thanks for the reply. I took all the belts out and cut them to the same length. I ended up cutting off around 3" to get them all the same. (4 belts are 10" longer than the other four belts) The repair manual I have says you can cut up to 10" off, but no more. I put new alligator splices in and squared them up real good before mounting to the belts.
Pabreak 84in Hydraulic Serrated Dozer Blade Skid Steer Attachment (A61567)
Pabreak 84in...
2019 FORD TRANSIT VAN (A60736)
2019 FORD TRANSIT...
2013 Ram 1500 Pickup Truck, VIN # 1C6RR6GP1DS541918 (A61165)
2013 Ram 1500...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59575)
2019 INTERNATIONAL...
Preliminary Listing / Full Catalog Coming Soon! (A57148)
Preliminary...
2020 DRAGON ESP...
