Help with hydraulics on 271
   / Help with hydraulics on 271 #1
purplewg
Member
I have a MF 271 and pulled it into the barn a week or so ago and everything was fine. Yesterday I went to use it and the 3-point arms won't lift. The front end loader works fine as does the aux hydraulics. I had changed the hyd fluids about a month ago and found some slime in the linkage strainer which I cleaned. Thinking maybe something had plugged it again I drained and pulled the filter again. The stainer is clean as a whistle. I am kind of at a loss as to what to look at next. Any ideas? Thanks
   / Help with hydraulics on 271 #2
If it has draft sensing, make sure you adjust/set it or it will not allow the 3pt to raise.
   / Help with hydraulics on 271 #3
Some tractors are equipped with a combining valve - a combining valve will direct oil flow that normally goes to the 3 pt and send it to the loader and rear remotes to increase loader speed. If that lever is in combined flow position the 3 pt won't work. Look for a lever sort of located on the backside of your legs and sort of under the seat.
   / Help with hydraulics on 271 #4
Thanks guys. My draft control lever had seized to my postion lever but had never caused a problem before. I kept saying I was going to take the assembly apart and unstick them. I guess the draft lever must have gotten just enough off to make it quit working. A little fire wrench work and some penetrating oil has it going again.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Kubota L4701 (A53317)
2018 Ford F-350 (A55973)
2018 Ford F-350...
2022 Brush Wolf ALPHA-XP Skid Loader Brush Cutter (A56438)
2022 Brush Wolf...
John Deere 4510 (A53317)
John Deere 4510...
