Rotary Cutter Rotary Mower Identification?
/ Rotary Mower Identification? #1
DennisZ
Santa Ynez, Ca
Kioti LK3054
I recently bought a used tractor and a rotary mower came with it. The seller couldn't tell me what make the mower was - and there are no ID tags, plates, serial numbers etc. I'd like to get a manual for it and possibly order some parts. Can anyone help me to id it? I've uploaded a few pics of the mower. Thanks for your help.
/ Rotary Mower Identification? #2
I see a lot of similarities to landpride, frontier, and johndeere. But cant find an exact match from any. Sorry I couldnt help. But it looks like a decient mower. What parts are you needing??
I've got a gear box oil leak so unless I want to constantly put oil in it I would replace the seals and maybe bearings. It's probably cheaper just to buy oil........ Thanks for the help. I'll do some online looking with those makes in mind. Thanks again.
/ Rotary Mower Identification? #4
Pump the gearbox full of grease and run it... It looks like a Woods...
/ Rotary Mower Identification? #5
Yeah, corn grease. That should keep you going till you can find the right seal.
/ Rotary Mower Identification? #6
I have found that when dealing with old or unknown equipment, it is easier to just take it appart and get the seals/bearings by size, rather than by MFG part #. Because if it is one of the three I mentioned, and you order seals and bearings from them, (or even any other for that matter), the cost is going to be about 3x's as much. Rest assured, that gearbox doesnt use any special kind of seals or bearings. Probabally just common off the shelf stuff that can be had at napa, autozone, or similar. And can be ordered online from about anywhere.
Landhonor SAD-12-23C Skid Steer Mount Auger (A62679)
Landhonor...
New/Unused Wolverine Quick Attach Auger (A65583)
New/Unused...
New/Unused Landhonor 6ft x 8ft Galvanized Apex Roof Metal Shed (A65583)
New/Unused...
2016 Boxer 700HDX Compact Skid Steer (A63109)
2016 Boxer 700HDX...
New/Unused Receiver Hitch Ripper (A65583)
New/Unused...
2007 Ford F-150 Pickup Truck (A64194)
2007 Ford F-150...
