d14 allis 3pt and loader controlled with same valve
/ d14 allis 3pt and loader controlled with same valve #1
leeandamie8675
Shell Lake, WI
Allis d14
I recently purchased an allis d14. In order to plumb for a loader someone put a tee in the input line of the 3 pt. They did put a shut off valve after the tee to disable the 3 pt. With out closing this valve, the 3 pt & loader operate with the 3pt. control on the steerin column. I would like to install another valve to control the loader. Could someone give me some direction as to what I need or where to go for help. Thanx, Lee
/ d14 allis 3pt and loader controlled with same valve #2
Im probably going with a double or triple valve to control everything if you can do that
/ d14 allis 3pt and loader controlled with same valve #3
Why notuse a joystick valve to control the loader like this.
Surplus Center - 2 SPOOL COMPACT 10 GPM JOYSTICK CONTROL VALVE
It has float and BP capability.
Your hyd flow might go something like this. Pump to input of FEL valve, PB out to a remote set of valves if you choose to install them, and then to 3pt.
Should you need a grapple later, you can use the rear remotes or add a diverter valve in the curl circuit.
/ d14 allis 3pt and loader controlled with same valve #4
I'm in the same boat as you with my allis. J_J, will a joystick work with the single acting system that the D14 has?
/ d14 allis 3pt and loader controlled with same valve #5
Any DA valve will work, just plug the B work port.
Does your loader use a SA or DA cyl?
/ d14 allis 3pt and loader controlled with same valve #6
It has DA cylinders and the unused side has a breather installed.
/ d14 allis 3pt and loader controlled with same valve #7
If, as you say that it is a DA cyl, then just use both work ports and run two hoses from the valve work ports to the cyl, and if you use the valve that I suggested, you will have float and regen.
A much better setup in my opinion.
/ d14 allis 3pt and loader controlled with same valve #8
Sorry, leeandamie8675 for hijacking you post but it may help both of us.
How will that work with the control lever on the column? Currently I have a selector valve in the line from the pump before it goes to the 3PH. From one of the ports it goes the the 3PH and the other goes to the loader cylinders. I use the column lever to raise (gravity lower) which ever one I want. There is no return line back to the pump. I would love to be able to operate the 3PH and loader independently of each other. Thanks for you help J_J !
/ d14 allis 3pt and loader controlled with same valve #9
To operate independent of each other you will likely need an auxiliary pump mounted to the front of the engine or the pto of the tractor. Most of those D series AC's had an engine mounted pump out the front, if you look at the grille on the front you will notice a knockout that can be punched out to run a shaft to the engine and there are holes on the front steering box casting to mount it. This was the ideal setup for that tractor so with the foot clutch in the pump will still run (vs a PTO pump). Typically the engine mounted pump used the loader frame as a hydraulic reservoir. I don't think with the current tractor hydraulic pump and capabilities that it will run a loader in a way to satisfy you, I've been all over a D14 and I don't know how you could plumb it to make it a double acting setup and still have your 3pt usable without using the loader or closing or opening a series of valves.
/ d14 allis 3pt and loader controlled with same valve #10
If he installs an aux PTO pump, and run the output through a joystick valve as suggested, the loader will be independent of any other hydrulics.
Just use your 3pt as you use it now.
/ d14 allis 3pt and loader controlled with same valve #11
Thanks guys! I had a feeling that I need to go that route.
/ d14 allis 3pt and loader controlled with same valve #12
another question, what series is it?
some of the early series used a high pressure/low flow system where the later series were normal pressures like a late model tractor.
IIRC the early system was not compatible with late model implements. and vice versa.
EDIT; this might not apply, I was thinking it was similar to the D17.
/ d14 allis 3pt and loader controlled with same valve #13
Lets back up here and see what you want to do?
What do you have and what do you want to do with any new hydraulics.. You say you have DA cyl's, and if so, then you can have power down and float and regen if you choose the correct valve..
So if you want an independent hyd system for the DA cyl's, then you need a pump, valve, and a reservoir.
Just use what yo have for the 3pt.
Do you have any idea of volume and pressure developed by the pump on your hyd system now?
I am running a 3 GPM pump, 3000 psi off of my fan belt.
You can do the same, and the pump is inexpensive.
http://baileynet.com/index.php?dnfwd=1&page=ProductDetails&line=GPGC&baileyno=250-058
http://www.surpluscenter.com/item.asp?item=9-7401&catname=hydraulic
http://www.surpluscenter.com/item.asp?item=9-4185&catname=hydraulic
Plus some hoses and fittings and filter.
2015 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A59228)
2015 Chevrolet...
2015 MGS GODWIN CD150M PORTABLE DRI-PRIME (A63276)
2015 MGS GODWIN...
BERKEL 909CT/1 SLICER (A64281)
BERKEL 909CT/1...
2016 New Holland Boomer 47 (A60462)
2016 New Holland...
3268 (A63117)
3268 (A63117)
Danuser 3pt Auger (A64119)
Danuser 3pt Auger...
