Clutch is grabby
   / Clutch is grabby #1
ACMan
Member
Olive Branch, Mississippi
I have about 350 hours on my tractor and this season I noticed the clutch does not engage as gradual as before. Its grabbing kind of hard. Any suggestions? I'm going to be changing out all the fluids hopefully this weekend. I adjusted the pedal last year.
Thanks
   / Clutch is grabby #2
Thanks
I'd check all the linkages, pivot point and springs and adjust it again per factory spec. Do you have any issues clutching and change gear? does it grind? when does it grab? I think there might be a possibility of release bearing distance to the pressure plate finger is more than factory spec needing you to clutch all the way and yet the clutch disk can't be fully released. If that is the case clutch need to be adjusted to engage quicker (shorter gap between pressure plate fingers and the throwout bearing).
JC,
BUYERS PREMIUM & PAYMENT TERMS (A51219)
BUYERS PREMIUM &...
2000 John Deere 770CH Articulated Motor Grader (A49461)
2000 John Deere...
STS MUD MIXING MACHINE (A50854)
STS MUD MIXING...
2025 GIYI Skid Steer Plate Grabber (A50322)
2025 GIYI Skid...
2020 New Holland 105 Workmaster MFWD Compact Tractor with 632TL Front Loader - Poultry Special (A51039)
2020 New Holland...
2017 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2017 GENIE GTH-636...
