Unfortunately JJ (thanks again for the advice), I only have the tractor's parts and operator's manual. I don't have a manual for the loader. I know when the Seller delivered it to me last month, he had no trouble lifting the 600lb ballast out of the back of his pick up. I know the three point hitch uses the tractor's hydraulics and the loader uses a belt driven pump. I don't know for sure when the fluids were changed last so I started the hydraulic fluid change this morning.
I found, according to manual, the filter is just a bolt??? So I removed both drain plugs, drain all the hydraulic fluid and then removed the filter(bolt), expected to see a screen of some kind, but no just a bolt with a hole in it and two washers.
Am I missing something. I could not find it my part manual. But found the motor oil filter information in the parts manual and it appears that has a similar set up, but with a screen. Haven't attacked oil/filter change yet as I just found out I purchased the wrong gear oil (GL-5) and need to return it and get the proper gear oil, UDT, I guess, even though the manual said 80W-90 .
What was troubling late yesterday and that we built a fire pit, so I had to move some gravel to the area in the back yard with tractor and the loader was having trouble lifting small amount of gravel and the higher I went, there was a jerky motion along with a very slow response. That's why I decided to do the fluid change this morning.
I have tilled, using the 6000 on three occasions and when the hydraulic tiller is working the loader does not, but the three point hitch works, if this helps any. I hope after the fluid change, it will solve my problem and it was just air bound and not a pump failure issues! Very strange, as I have been messing with tractors for 25 years or so!!!
Thanks again for all your help JJ!
