John Deere 375 Backhoe
/ John Deere 375 Backhoe #1
abundyg
Sault Ste Marie, Mi
John Deere 3720
I just purchased a 375 backhoe and after using it i was alittle disappointed I found that the backhoe couldn't lift the back of the tractor off the ground is this normal? I have the 3720 tractor with a cab and loaded r4 tires. Also does anyone know if there is a way to increase the pressure to gain more power out of this unit?
/ John Deere 375 Backhoe #2
I have a 7 backhoe I recently bought and noticed that it's main relief valve is set at 1700psi. This seems odd to me since my tractor operates at 2700psi. I don't think it's set that low to protect the hydraulic components as much as it is to protect the hoe itself.... to keep from bending things, etc. Either that, or with the relatively light weight of the tractor, they're trying to keep the hoe from dragging the tractor around.
Does anyone know if there is a different relief valve that can replace the existing to increase the pressure
/ John Deere 375 Backhoe #4
I don't think it's normal , your hoe is made to fit your 3720. Should be able to lift it right off the ground. My backhoe is smaller then yours in size an weight, but will lift my tractor right up. Just my opinion.
/ John Deere 375 Backhoe #5
In the case of the 7, there is a shim stack in the relief valve. To alter it's set point, you'd have to either add or remove shims or swap out the spring to a different rate. Either way, you'd better know what you're doing and be fully prepared to accept the consequences of your actions.
/ John Deere 375 Backhoe #6
On the 3x20 series the system relief pressure should be set to 2500 psi. This is set by adjusting the relief valve on the SCV. To increase pressure turn it clockwise. If you break something don't blame me. This should be done using calibrated gauges and such. Mine is set @ 2300 psi according to an uncalibrated gauge and the 447 hoe (same as 355 mostly) can lift my open station with loaded tires off the ground.
/ John Deere 375 Backhoe #7
Are you saying that your 447 does not have its own relief valve?! All the hoe
attachments I have owned or operated had their own RV.
Therein lies the problem, err feature. The hoe RVs are very often not set
correctly for your tractor. The 3x20s have a 2500 psi rated pump, so the
hoe should be operated at 2500psi.
Some hoes are only rated for 2000psi, so they are set near that value,
hopefully. But outgoing QA is not always good.
Since many hoe attachments are sold for unknown tractors, they have
their own RVs. It is certainly POSSIBLE that one does not, but unlikely, IMO.
Note that many hoes can be attached to the 3-pt and/or used with a PTO
pump system that has no RV of its own.
As for the OP's 375, his hoe's RV is set way to low, or the boom piston seal
is possibly blown. Even at 2000psi, all these hoe attachments, working
properly, can lift these CUTs no problem.
/ John Deere 375 Backhoe #8
There is a video on YouTube of someone selling a 3720 w/375 and he lifted it of the ground no problem and it was a cab model. I will try and find it. I looked at it this morning.
Also what rpm are you trying this at just be sure?
/ John Deere 375 Backhoe #9
Out of curiosity are you using Power Beyond to run the BH or 3rd SCV?
/ John Deere 375 Backhoe #10
I have a 3320os with a 47 backhoe and mine will lift the back end off the ground and move it side to side BOB
/ John Deere 375 Backhoe #11
I apologize for any confusion. The 375 and 447 hoes also have main system relief valves and several circuit relief valves. The main circuit is set 2250 psi. It too is adjusted via an adjustment screw.
I probably should get paid by Deere for promoting their technical manuals, but I do it for free. The manual on the tractor series is nothing less than phenominal. The one on the hoe covers a lot of models all jammed together, but is still a worthy product. I advise all JD owners to buy them for their specific models.
I have tried at all different rpms and i am still waiting to hear back from the dealer i purchased from. I appreciate all the advice and i will have to check the pressures to make sure they are where they should be.
Yes this is hooked up to the power and beyond on the tractor.
/ John Deere 375 Backhoe #14
Let us know what you find, an just remember alot of backhoe operators depend on moving around to reposition theirself on the hoe. Just one reason to be able to lift your tractors rear with the hoe.
/ John Deere 375 Backhoe #15
Here is that video and this was actually a 3520 and not a 3720, but the same setup otherwise. The hoe seems to have plenty of power and didn't seem to stress raising the rear at all there.
John Deere 3520 - YouTube
UNKNOWN TANK MANIFOLD (A58216)
UNKNOWN TANK...
78" GRAPPLE RAKE W/ UNIVERSAL SKID STEER MOUNT (A63290)
78" GRAPPLE RAKE...
4022CFL (A59228)
4022CFL (A59228)
2012 MACK CHU (PINNACLE) (A63569)
2012 MACK CHU...
2010 International 4300 2,000 Gallon Water Truck (A64194)
2010 International...
2010 Ford Crown Victoria Sedan (A61574)
2010 Ford Crown...
