Kubota B7500 overheating
/ Kubota B7500 overheating #1
Sacwarrior
Shaftsbury, VT
Kubota B7500
I have a Kubota B7500 with bucket and RCK 60 24B mowing deck with around 660 hours. I lubricate the deck every other time I mow. In the past on really hot days while mowing my 4.5acres of grass it might overheat. When it did, i would stop, clean the filter and grille and the temperature gauge would drop quickly. Today it went over the red line but there was little grass blocking the air flow. I went back to the barn and blew off the grille and filter as well as the radiator. The fan belt seems to be fine, no noise coming from the water pump housing. I flushed the radiator until clear and the temperature gauge stays above the red with the PTO off. The service department where I bought it suggested I take the radiator out and take it to a radiator shop. Any other thoughts before I try to do that?
/ Kubota B7500 overheating #2
I presume it has a thermostat like most water cooled engines.I would take it out and check it in a pan of water on the stove to make sure it's opening far enough and at the right temperature.
/ Kubota B7500 overheating #3
Yeah - take off the radiator cap when cold and then fire it up and let it warm up.
Observe the temp gauge and if it goes up towards the red stick an actual thermometer into the coolant and take a reading.
All that may be bad is the sending unit for the gauge ....
/ Kubota B7500 overheating #4
Have you checked that the radiator isn't plugged with dirt and grass impeding the flow of air through it thus preventing it to cool? That was the problem with mine when I first bought it, and it had been serviced by a Kubota dealer several times for overheating.
I flushed the radiator and let it stand overnight. In the morning when I turned the ignition on the needle went back to the red line. I should have figured then that it was probably the sending unit or a connection, but I took out the thermostat and found it was stuck OPEN. Not a problem now, but a different issue next winter. I found the sending unit on the right side of the engine near the firewall and wiggled the wire coming out of it and the needle went to dead zero. I'll probably have to replace that and the thermostat at some point. Meanwhile I was able to mow for about an hour and a half today with no evidence of overheating. The gauge did flicker on some bumpy hills, so I think the connection is bad there.
Thanks to everyone who offered suggestions.
/ Kubota B7500 overheating #6
I would use some pliers to squish the plug onto the sender a little so that it has a better connection.
Aaron Z
2017 Cadillac Federal 70IN Limo w 27466 Miles, Premium Federal Coachwork, Luxury Transport (A63689)
2017 Cadillac...
2013 Bobcat T190 (A64126)
2013 Bobcat T190...
New/Unused Landhonor Pallet of Chains and Binders (A65583)
New/Unused...
2025 IREV Electric Scooter (A64194)
2025 IREV Electric...
2015 PETERBILT 567 6X4 T/A DAY CAB TRUCK TRACTOR (A66091)
2015 PETERBILT 567...
2006 TerraGator 8104 (A63688)
2006 TerraGator...
