Ford 540 Industrial Shared Components?
   / Ford 540 Industrial Shared Components? #1
Millsonwheels
Hello,
I was wondering if anyone out there knew what Ford / New Holland tractors have the same components as on our 540 industrial tractor: 8 speed trans, 55 hp 3 cyl diesel engine, rear end, etc.
Any help would be greatly appreciated.
Thanks,
Mills
   / Ford 540 Industrial Shared Components? #2
Fords are component tractors; commonality is too great to list, literally. Most any major component will swap into any 3 cylinder Ford tractor built between 1965 and 1999 with a little rework, and often without any rework at all. If you have specific application questions, post back.
Well I was just mainly curious about the motor and the transmission, If I can label the parts as from something more common, say the 1000 series It should be much easier to find.
   / Ford 540 Industrial Shared Components? #4
4600 ag tractor components and 555 TLB components will generally swap in; all being built in similar timeframes as a 540. Any transmission or rear axle housing out of a 3 cylinder Ford with planetary final drives and similar PTO arrangement will swap in. Any 3 cylinder Diesel engine from 1965 through 1999 will bolt in and be made to work.
   / Ford 540 Industrial Shared Components? #5
I think RickB is right. The guy I bought my 540 industrial tractor from said it was most like the Ford 4000 series which seems to match up with what I have been able to figure out from decoding the serial number and looking at those machines.
   / Ford 540 Industrial Shared Components? #6
The 540 post-dates the 4000 hence the reference to the 4600 all purpose tractor and 555 TLB.
2008 Ford F450 (A49461)
2008 Ford F450...
2017 Ford F-250 4x4 Knapheide Service Truck (A50323)
2017 Ford F-250...
2013 VOLVO VNL860 TANDEM AXLE SLEEPER (A51219)
2013 VOLVO VNL860...
2014 FREIGHTLINER CASCADIA (A50854)
2014 FREIGHTLINER...
2011 L3 MEP-806B GENERATOR (A51222)
2011 L3 MEP-806B...
2018 Dodge Charger Sedan (A50324)
2018 Dodge Charger...
