Rotary Cutter Help with Brush Hog?
/ Help with Brush Hog? #1
Mn Snowman
West Central Minnesota
Bobcat Ct235
I Picked up the old 5' Brush Hog pictured below! Does any one know what brand it is? There is no ID plate anywhere on it. I did see a picture of a old Ford hog that looks somewhat the same but the gearbox was not the same.
It works great but the blades could be replaced!
/ Help with Brush Hog? #2
Best to probably pull a blade and measure hole diameter, blade length and any offset then search for matching blade. Had to do that for a 30 yr old off-brand rotary I have. Good luck.
/ Help with Brush Hog? #4
Local tractor shop in WA had blades (and stump-jumper plate). I think a lot of mowers used same/similar gearboxes. Other forum members might have sites for reasonably priced blades.
/ Help with Brush Hog? #5
Did you find out the make and model of your machine? I just bought one today and it looks just like this. The seller thinks it is a Ford but I have not found anything online that matches it.
Not sure but all the bolts have a "I/H" on them! International Harvester I think! I asked the dealer but they said it's so old they would not have any info on it!
2019 PETERBILT PB337 LUBE TRUCK (A63276)
2019 PETERBILT...
2022 CATERPILLAR 299D3 XE SKID STEER (A64279)
2022 CATERPILLAR...
(50) UNUSED 3'x8' CORRUGATED METAL SHEETS (A64281)
(50) UNUSED 3'x8'...
2017 TROXELL 150 BBL ALUMINUM VACUUM TRAILER (A63569)
2017 TROXELL 150...
2022 Mac Trailers 48ft. T/A Walking Floor Trailer (A61573)
2022 Mac Trailers...
John Deere 12in Channel Tooth Bucket Excavator Attachment (A64194)
John Deere 12in...
