FEL Frame mount alignment
/ FEL Frame mount alignment #1
Ord
Ontario, Canada
Kubota BX1860
Hi,
today I was not able to get the loader onto our BX1860 - it seems like the right hand frame mount is angled slightly outward instead of facing straight ahead like the left hand side. Does anyone know where/what I should measure to check this, and is there any way to adjust it?
The last couple of times I put the FEL on it was hard to get both pins in - I would get one in, then have to get off the tractor and tug the bucket to one side to get the other to line up properly. Now no matter what I try I can't get it to line up.
Thanks,
Ord
/ FEL Frame mount alignment #2
I think about the only thing you can do is just back all the bolts out about 1 turn and see if it well move any by itself.
I would do it with the loader on and on a flat surface. All hyd. pressure off of the boom and the bucket flat on the surface. It just might help.
Thanks.
I took another look at it, and I can see now that the frame mount is bent. Not sure how I did that, or how I can straighten it.
I took the frame mount to a machine shop and they straightened it with their press. Now I can get the loader on again. Taking it off it sticks a bit - rolling the bucket back isn't enough to get it to lift off, I have to go and step on the front edge of the bucket to get the arms to lift out.
/ FEL Frame mount alignment #6
I had to do the same thing for the 1st few times taking it off. It went away by itself, it might of just been the paint making it tight fit.
/ FEL Frame mount alignment #7
glad you got it all taken care of.
question Have you watched the utube videos from messicks on taking loader off?
Thanks, I just went and watched it. There was another video I had watched before, posted here on tractorbynet that also showed the removal... I forget now who posted it.
I think my problems may have started when I tried to remove it one day with the teeth (ratchet-rake) installed, and on an uneven surface.
2020 CATERPILLAR 140 AWD MOTORGRADER (A63276)
2020 CATERPILLAR...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A61567)
iDrive TDS-2010H...
2021 UTILITY VS2DX 53FT DRY VAN (A59905)
2021 UTILITY VS2DX...
207275 (A52708)
207275 (A52708)
Ford F800 (A63689)
Ford F800 (A63689)
2010 Chevrolet HHR SUV (A61574)
2010 Chevrolet HHR...
