everything backwards on DK50SE
/ everything backwards on DK50SE #1
krazsk
Bobcat CT225, McCormick X10.50H
Has anyone else been confused with everything being backwards on the DK50SE vs the CK28? Brake pedals on left, brake lock pulls up vs push down to engage, push forward pedal to back up, the volume control on the radio is the right hand knob, the tuning knob is on the left. Instinct is alway wrong switching from one tractor to another. "But then, I'd ***** if they hung me with a new rope" :)
/ everything backwards on DK50SE #2
I got caught with the brake once. I had parked on a slight incline with the HST in gear, bucket lowered and brake not set. Turned tractor off to pile some brush. Then shifted to neutral and started the tractor. When I lifted the bucket the tractor rolled back 15' or so into a barbed wire fence, with me pushing on the HST pedal as a brake (but it was in neutral) and then finally hitting the brake on the left side. I broke the top 2 strands and creased a fender. But now the layout is familiar and automatic.
I think the left vs right brake pedal has been argued several times. I'm a fan of the left side brake pedal for an HST since it is easier to use the split brake function when required.
The dual HST pedals seem natural to me, but I've never used the rocker style which would be a push-back-to-go-back operation. It did take a couple of times for me to get used to letting up on the HST to increase hill climbing ability.
The parking brake seems natural for me. I don't have a radio but your description does seem backwards. Then again, I don't even use the radio I have in my vehicle. Perhaps the radio is a Korean thing--do they drive on the left like the Japanese? I always need to remember that when refueling my Nissan truck as the gas filler is on the right instead of the left as most North American cars.
/ everything backwards on DK50SE #3
This is why I think that the "safety" interlock of requiring you to be in neutral to start the engine
is all wrong for a HST tractor. I keep mine in gear all the time.
Newer Kiotis have gone to electric PTOs and no foot clutch, like many other HST machines.....good
for braking-turns; not so great for feathering the PTO on/off.
I was surprised to see the Bobcat version of the CK30 reversed the engine speed control lever
versus the nearly identical Kioti unit.
KRAZSK: I don't get the pushing of the FWD pedal to back up. ??
Yeah, I probably wasn't clear, the rocker hydro pedal vs the front and back separate pedals. When you jump from one tractor to the other, your foot doesn't naturally do the "correct" thing. You have to "think" for the first few minutes.
/ everything backwards on DK50SE #6
Well I will say this, coming from a Kubota L3400, clutch on the left, brakes on the right, single long rocker treadle pedal. Do not have to be in neutral range to start, but have to have clutch pushed in.. PTO was a little lever on the right side behind you, activate that then slowly let out clutch... everything is different with the Kioti. and it took me maybe 10 to 20 hours to become totally acclimated. It all seems fine now..
James K0UA
/ everything backwards on DK50SE #7
Brake lock pulls up vs down gets me all the time. I'm thinking it's because it's new and hasn't really broken in yet, but it's still pretty stiff so I'll try the old way with no luck then the new way with no luck then get confused before it finally locks. The other one that drives me nuts is the range selector, high is forward now instead of backwards like before.
When I used the witch word with the capital B, it was sensored. That was surely not meant to be offensive, and is not considered where I live to be offensive. If anyone took it as offensive, I apologize, but it was not intended that way.
/ everything backwards on DK50SE #9
Its about the policies of TBN and is not allowed whether it was meant to be offensive or not, is irrelevant. It has nothing to do with where you live. When you signed on to TBN you made an agreement to not use any offensive language, etc.
/ everything backwards on DK50SE #10
Yeah. We never heard that kinda language before . We're all alter boys here. Personally I've never even said those words but now I'm gonna start. All because of this thread. My life is forever changed. Thank you TBN and next time I'm not buying another Chinese tractor that I have to fix every time I use.
/ everything backwards on DK50SE #11
Maybe you should be posting this on your Chinese tractor forum.
This is the Kioti forum and Kioti's are made in South Korea.
/ everything backwards on DK50SE #12
Are you planning on showing your complete lack of knowledge in every thread? Reviewing a few of your posts, you seem to like to $H1T on pretty much everything people have to say for no apparent reason. Ooopps, sorry, that's probably another new word for you, your vocabulary must be getting close to 100 now.
/ everything backwards on DK50SE #13
I suspect you mean altar boy?! Regardless, this isn't about you, or me as messenger, it IS about if you want to post on TBN then LEARN the required policy which EVERYONE agreed to when they signed on. If you aren't interested in following them, then go elsewhere.
Chinese tractor? What does that have to do with this forum about Kioti tractors?
/ everything backwards on DK50SE #14
Here we go again!. Isn't there a way possible to get a point across without being rude.I believe some of you have no communication skills.being rude or condescending is just as bad as using bad language if not worse.quit building yourself up by putting down other while hiding behind TBN rules.
/ everything backwards on DK50SE #15
The point was the OP was censored by the admin for using inappropriate language. The ones who do this seem to always have some excuse for having done so; or someone else chimes in about some completely irrelevant nonsense that is supposed to sting the person, in this case, me, who merely points out the contractual obligation each of us has regarding these rules. Then guys like you come along and vaguely and judgmentally conclude I'm being rude- that is what you're implying is it not?
Fact is these issues almost always end up derailing a thread because everyone wants to give their opinion about who has to or doesn't have to follow the rules. I'm not hiding behind anything. I'm not putting anyone down or building myself up as you put it, again assuming your speaking of me, to me. The rules are just that, the rules. Everyone needs to abide by them or else be censored, or removed from TBN.
I have absolutely no problem communicating; if it seems rude to you maybe its actually about your ability to grasp what I'm conveying- focus on the topic at hand, follow the rules, complain about Chinese tractors in the Chinese tractor forum. This way those of us who actually want to help others solve their tractor problems like me, can do so without all the needless argument about nothing.
And to answer the question about a way to get a point across without being rude; if those who seem, or claim ignorance of the rules or the inability to use inappropriate language on this site, would read the rules prior to engaging in behavior not allowed on this site, there wouldn't be a need to point things out in whatever way needed to finally, hopefully, get the point across to them, and the others, who always chime in about the injustice of it all- the censoring of their rights to do whatever they want wherever and whenever they want.
2016 International Workstar 7500 T/A Dump Truck (A61573)
2016 International...
2013 Chevrolet 3500 Dually (A62613)
2013 Chevrolet...
2005 Toro Z Master Commercial 72in Zero Turn Mower (A61572)
2005 Toro Z Master...
ABI 80-ASRT-074 Command Seeder Tractor Attachment (A61572)
ABI 80-ASRT-074...
2003 Toyota Tundra Extra Cab Pickup (A62613)
2003 Toyota Tundra...
More info coming soon (A61574)
More info coming...
