Calculating fuel left in a storage tank.
   / Calculating fuel left in a storage tank. #1
IMCA38
SE Nebraska
MF 1225 w/loader, Case 1840 SS, Ransomes 723D mower
Has anyone ever figured out how many gallons are in a typical 300 gallon storage tank based on poking a yardstick in the tank? My tank is approximately 36 inches in diameter by approximately 60 inches long.
I presently have 13 inches of fuel in the tank. Without doing mathematical calculations that I'm incapable of doing, I would guess I have between 60 and 75 gallons left in the tank.
Anyone care to agree or disagree?
   / Calculating fuel left in a storage tank. #2
If it's 36" dia, and it's 13" deep, isn't that a little over a third ?
What am I missing ?
   / Calculating fuel left in a storage tank. #4
When I copy that as text it doesn't format exactly as I expected. There are three columns. First is a line number, second is liquid depth, third is the volume.
Element depth volume
1 1 2.0605
2 2 5.7783
3 3 10.523
4 4 16.058
5 5 22.238
6 6 28.963
7 7 36.154
8 8 43.747
9 9 51.687
10 10 59.928
11 11 68.427
12 12 77.145
13 13 86.047
14 14 95.099
15 15 104.27
16 16 113.53
17 17 122.85
18 18 132.19
19 19 141.54
20 20 150.85
21 21 160.11
22 22 169.28
23 23 178.34
24 24 187.24
25 25 195.96
26 26 204.46
27 27 212.7
28 28 220.64
29 29 228.23
30 30 235.42
31 31 242.14
32 32 248.33
33 33 253.86
34 34 258.61
35 35 262.32
36 36 264.38
Thanks for the info!
I arrived at my conclusion by guesstimating that the middle 1/3 had to be about double of the top or bottom 1/3. Therefore, the bottom 1/3 would be about a quarter tank volume-wise.
Nice to know that there might be more than I thought!
   / Calculating fuel left in a storage tank. #6
The numbers are valid for your dimensions. If the dimensions are different you need to increase/decrease the volume proportionally. If I get bored tomorrow at work I will make a Excel spread sheet to calculate it and post it.
The attached file is selfextracting. To make it work copy it to your HD and change the extension from txt to exe.
   / Calculating fuel left in a storage tank. #7
   / Calculating fuel left in a storage tank. #8
I would disagree with your beginning capacity. According to this on line calculator using 60" for length and 18" as a constant radius your tank holds 264 gallon.
barrel Volume and Gallons Calculator
When your distributor fills the tank he normally leaves some room for expansion at the top.
Older tank designs usually slope toward the back so any dirt will accumulate there plus the outlet of the tank to the hose is normally a couple inches up from the bottom, so in either or both cases you will not get all the fuel out unless you physically lift the back of the tank frame.
I use a stick to determine the level in the tank, but to get the exact gallons available at the nozzle from that is calculable but not useful in real life.
I find it simpler and much more useful to keep a clipboard in the barn where I note the gallons delivered at fill up and then each time I draw down the tank indicate the date, which tractor, what purpose the tractor was primarily used for since the last tractor fill up, and the hour meter reading on the tractor.
Normally I run the tractors until the fuel gauges indicates a warning to fill up. Knowing the capacity of the tractor fuel tanks and how many times I have filled each then gives me a simple warning of when it is time to stick the tank for a level. That way I am sure the distributor will have room in the tank to put at least the minimum amount in without rendering a sir charge for not enough gallons.
Depending on the planned use/harvest I may have to make a hurry up phone call, but I usually remember to check it at least a week in advance of when I would run out.
   / Calculating fuel left in a storage tank. #9
I attached the calculator to my original post. It assumes the tank is cylindrical laying horizontally.
Disclaimer- In my initial post, I said dimensions were approximate.
Playing with the calculator you attached, you can stretch things an inch or so and get really close to 300.
I said approximate dimensions because I used my yard stick to measure the tank. I did have to tie a string on the yardstick when I stuck it in the tank, so the diameter could easily be 37" + and the 60" length is a little if-fy with the yardstick too.
In the name of accuracy, I'll have to measure with a tape and see what it is.
2018 KENWORTH T370 T/A DUMP TRUCK (A51406)
2018 KENWORTH T370...
2016 Ford Fusion Passenger Car, VIN # 3FA6P0G79GR191653 (A50324)
2016 Ford Fusion...
2006 CATERPILLAR 330DL EXCAVATOR (A51242)
2006 CATERPILLAR...
2019 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2019 Ford F-450...
UNUSED AGT QUICK ATTACH AUGER SET (A51244)
UNUSED AGT QUICK...
UNUSED JCT SKID STEER QUICK ATTACH PLATE COMPACTOR (A51244)
UNUSED JCT SKID...
