Backhoe Is the new Bobcat backhoe a 3 pt. attachment?
   / Is the new Bobcat backhoe a 3 pt. attachment? #1
Mike Fortner
Chesapeake Va.
Bobcat CT 235
Does any one have a new Bobcat back hoe out there? The new ones on the Bobcat web page look like 3 pt. hitch attachments instead of the frame mounted original units. If so , are they less expensive ? Are they less sturdy? and are they easier to attach?
Thanks in advance for the info.
   / Is the new Bobcat backhoe a 3 pt. attachment? #2
The backhoe is still the same sub-frame mounted.
   / Is the new Bobcat backhoe a 3 pt. attachment? #3
I have one and it works well. It still has the sub frame, but it also has the holes to be installed as a 3pt mount. I have never used it has a 3pt mount however. Once you get used to the sub frame mount, it can be changed in about 10 minutes. I previously has another brand 3pt mount back hoe and it was a pita to take on and off. It could be don't in 30 minutes when the stars were all aligned and 2 hours when they were not. It had a pto pump on it however. I like my bobcat much better. Plus you can use more of the weight of the tractor when digging.
Sent from my iPad using TractorByNet
   / Is the new Bobcat backhoe a 3 pt. attachment? #4
Believe it or not, I asked a dealer that same question this morning, because the Bobcat website says "3-pt. backhoe".
He said they are indeed subframe mounted.
Whatever you do, DON'T get a 3-pt. mounted backhoe. Subframe mount is much stronger and much more convenient for on-off.
   / Is the new Bobcat backhoe a 3 pt. attachment? #5
I just got a quote on a 7TL BACKHOE FROM bOBCAT. iT IS $9000 for the hoe, subframe and 2 remotes. I am going to go and look at one this week because I have never seen THE Bobcat backhoe. I think that I am going to pull the trigger and get it. I was going to get a woods 80BH but the quote was $10,600 plus 2% of financed ammount. That was too much for me.
   / Is the new Bobcat backhoe a 3 pt. attachment? #7
I have a 8tl backhoe attachment. I just got it maybe two months ago....great digger for sure, and yes its subframe mounted.
I am putting it up for sale though, too big for what I need....
2012 DODGE RAM 5500 FLATBED (A58214)
2012 DODGE RAM...
(4) SHEETS OF 11 GAUGE STAINLESS STEEL (A58374)
(4) SHEETS OF 11...
SKID STEER ATTACHMENT GRAPPLE GRUBBER (A58214)
SKID STEER...
2019 CATERPILLAR  XQ60 GENERATOR (A58214)
2019 CATERPILLAR...
2005 MERCURY Grand Marquis Sedan (A56859)
2005 MERCURY Grand...
GEARMATIC WINCH CABLE DRUM (A58214)
GEARMATIC WINCH...
