Stopping a leaking cylinder
/ Stopping a leaking cylinder #1
tpulley
Wake Foest NC
Kioti DK45SE
I have a post driver that is leaking pretty bad. Not bad enough I refuse to use it but bad enough I am concerned I am losing maybe 1/2 -3/4 a gallon with every 5 hrs of use.
I am wondering about rebuilding the cylinder. Where would one get parts especially when I am not even sure what it is. Would it be easier to just get a new cylinder? It would be cheaper to get a seal I would think if I could find it.
Any ideas where to start? Where do you measure to determine the size at the largest diameter or at the piston?
Forgot to attach the pic I took of it.
/ Stopping a leaking cylinder #3
Who makes the post driver?
If you don't know how to measure the groove width depth, bore, etc, take it to someone that does know how.
/ Stopping a leaking cylinder #4
You could take the cylinder to a hydraulic shop and they might be able to set you up with a seal kit for it. Seals are usually pretty cheap compared to a new cylinder. But if you have them do the rebuild. Then you might be able to get a new cylinder cheaper or for about the same price.
Check out surpluscenter.com for some cylinders.
Chad
/ Stopping a leaking cylinder #5
It looks like a Prince "Royal Line" cylinder...... http://www.princehyd.com/Portals/0/products/cylinders/RoyalLinePartsBook.pdf
If the snap ring comes out of the bore in the gland then it will be easy to rebuild.........:confused2:....but the rod in your pix looked like it could be pitted (rust under the chrome plating).....if so then I'd be sizing it up for a new cyl replacement
if the rod looks like new and the snap ring comes out then it should be worth the trouble to reseal/rebuild.....easy parts to obtain from any hyd repair shop
Thanks Guys I am going to take it apart in the next fe days and see if I can figure out what it is and if I can get the seals and or a complete overhaul for it.
/ Stopping a leaking cylinder #7
No problem. Wish you luck in getting it fixed.
Chad
Ford 8210 (A60462)
Ford 8210 (A60462)
2019 Ligchine Spiderscreed Concrete Screed (A59228)
2019 Ligchine...
2023 ATLAS COPCO XAS 188-49 HP PORTABLE AIR COMPRE (A62129)
2023 ATLAS COPCO...
211298 (A62131)
211298 (A62131)
HOMEMADE 25 GALLON ELECTRIC AIR COMPRESSOR (A62131)
HOMEMADE 25 GALLON...
2022 Big Tex Trailer Trailer, VIN # 16V3F4822N6178218 (A61165)
2022 Big Tex...
