jeff9366
Super Star Member
- Joined
 - Jan 14, 2011
- Messages
 - 12,787
- Tractor
 - Kubota Tractor Loader L3560 HST+ ~~~~~~~~~~~~~ 3,700 pounds bare tractor, 5,400 pounds operating weight, 37 horsepower
Scattered around the ATTACHMENTS and OPERATING Forums are references to using chains to limit Rotary Mower drop, rather than relying on the 3-pt control adjustable stops; however there exist minimal photos.
I was told there was a junked rotary cutter lying in the grass in a remote area of the three-year old housing development where I live in North Central Florida. After chopping it out of the jungle I found a sad King Kutter L-48-40-P-Y, with quite a few missing parts. As I had "0" rotary cutter experience I decided to resurrect this implement and use it as a "learner." I have "invested" about $300 on parts, including chains. Todays evolved version of my King Kutter L-48-40-P-Y is the L-48-40-P, which sells for $800 new.
My tractor/loader is a 2011 Kubota B3300SU Package / 33-hp / 25-hp PTO, with the famous, or infamous, Kubota 1/4"-ing 3-pt adjustment. To make a long story short, I could not get the mower height to hold. The Kubota mechanic at my local dealer, where I bought the tractor/loader, could not get the height to hold. He called the Kubota Consulting Mechanic....who suggested chains. At this point I started reading every relevant post I could find on T-B-N; and I got some ideas.
I note that this is the sole attachment with which I have had issues relative to 1/4"-ing. None of my other implements are deck height critical.
I started by installing the chains to hold up the REAR of the cutter. A pair of factory holes were available at the rear of the frame and most archive T-B-N posts I read dealt with suspending the rear of attachments. See the pictures. I keep 5/16" and 3/8" chains on the tractor. After making some measurements the 3/8" chain seemed about the right length so I used it, rather than the 24" longer 5/16" chain. The 3/8" chain supports the cutter deck from a 3/8" shackle pierced by the lower of two top link pins. (Top Link in this application is on top pin.)
The 3/8" chain is much heavier than necessary. The cutter weighs 425 pounds which is supported at four points on the tractor: two lift arms, chain/frame and the tail wheel. Not much weight on any one support point. I used 3/8" chain only because it was at hand and just a bit longer than necessary.
It is difficult to see in the shadow but there are SIX bungee cords wound around the cutter frame and hooked into 3/8" chain links to keep the chain absolutely away from the PTO shaft. Very redundant. Very safe.
The chain drop-limit works FINE, however I could not mow lower than 5", a safe height to get my first experience with this powerful and potentially dangerous attachment.
With the chains taut there is 50-60 pounds of downward pressure on the tail wheel. The skids are 6-1/2" above ground at the rear, 5" at the front.
The PTO safety shield was very brittle. I attached it with two tether chains, one at each end of the PTO, which you can see in the photos, but half of the shield soon dropped off in chunks. The two limit chains and 3-pt cutter mounting frame pretty well shield the PTO. A third chain down the middle would complete an enclosure.
All this worked FINE @ 5", except I wanted to be able to cut @ 3-4". After awhile I realized that I need to limit drop at the front of the cutter NOT the rear.
I bought more hardware to set up the front-limit chains and installed everything this afternoon but before I could take photos it started to rain heavily so I will make a separate rear-support dedicated post tomorrow, with photos, covering the front limit-chains.
Just as well. This can stay a "pure" thread on rear deck limit-chains.
I hope this helps someone.
