Next Project - Lawn Irrigation
/ Next Project - Lawn Irrigation #1
Kubota Tee
Gold Member
Hudsonville, MI
Kubota L5740 HSTC-3, Kubota L3540HST-3 (sold)
One of the joys of developing a 3.5 acre lot is the never ending list of projects that needs to get done - let alone all the seat time I get on my Kubota!!
My next project is to install an irrigation system for the property. Here's my question for the more creative minds out there - what is a good way of hiding the pump and associated plumbing manifold that will have to be installed near the shoreline. One idea that my wife had was to build a bench with an arbor around it, hiding all the bits under the bench. Not a bad thought!!
What other creative thoughts are out there? Or perhaps you have already conquered such a project and would like to share your results. Pictures are especially welcomed!! :thumbsup:
Here's a Google Earth picture of our property with the proposed pump location indicated.
/ Next Project - Lawn Irrigation #2
Irrigation valves are designed to be installed below ground inside plastic boxes with lids. There are several types of the boxes from ones that only cover one valve to ones that can hold a manifold with several valves.
This is, of course, if you intend on using electric irrigation valves that connect to a clock timer for operation. If you were planning a "manual" manifold with gate/ball valves - think again ... a few trips to a manual system when you are tired or whatever will make you wish you had automated the system.
Is the well already in or are you pulling the water from the pond/lake? Will the pump be above ground or submersible? There are many ways to disguise them, and they each have their good/bad points.
Are you planning on installing the system yourself? Much will depend on the flow your system delivers when it comes to designing and installing the system.
/ Next Project - Lawn Irrigation #3
All my irrigation stuff is underground. I ended up making valve boxes out of 2x6 pressure-treated wood sides, with pea-gravel bottoms. That way I could customize the size, and they were a heck of a lot cheaper than the plastic boxes. The tops are pressure-treated 1" decking and don't look bad at all. I let them weather to a natural color, but you could stain them or even paint them green I suppose.
Most everything can be below grade (and that's actually more convenient if you are running lines and placing sprinkler heads in the ground anyhow). Just be sure to put some union joints in strategic places inside the valve boxes so that you can pull out and replace components without having to tear out a whole manifold or assembly.
My system is for the lawn, with 9 zones and about 50 sprinkler heads. I put in about 1200 feet of pipe, a combination of 1" PVC (came in 20' sticks with flared ends) and 1" black poly (came in 200' rolls). There is a main manifold in my crawl space under the house that taps into the water supply, with a backflow preventer, meter, manual ball valve, automated master valve, and air fittings (to allow me to blow out the system for winterization). That feeds two outdoor valve manifolds, one for the front yard (3 zones) and one for the back yard (6 zones). Each manifold is in one of those wood boxes below grade (located in a central area to each zone for the simplest trenching/piping/wiring routes).
/ Next Project - Lawn Irrigation #4
You're in Michigan so you have frost/freeze issues to deal with on equipment and pipes above or slightly below ground level. If you do build a bench type structure, perhaps make the seat wider than normal and box it in underneath to fully hide your equipment andfreeze protect with heat strips.
There's a family in our town and instead of a bench, built a scaled down version of a classic outhouse for their lawn irrigation equipment. Time to be tastefully creative-in your case, how about a scaled down light house?
/ Next Project - Lawn Irrigation #5
You should check for local regulations on depth and types of hook-ups. If you are pulling from that water in the picture there would probably be no need for a back-flow but if you are using a well that is shared with the house a back-flow is needed - however local regs will determine what type of back-flow needs to be used.
...I ended up making valve boxes out of 2x6 pressure-treated wood sides, with pea-gravel bottoms...
I have no problem with building your own boxes - a standard plastic rectangular box should cost less then $25 from a DIY center and less from an irrigation supply - they never rot and can fit 6 1" vales. However, I would NEVER put any gravel, rock or anything else in the box. If you ever have to work on it later and need to dig it back up - you will know why I say this.
... Just be sure to put some union joints in strategic places inside the valve boxes so that you can pull out and replace components without having to tear out a whole manifold or assembly...
I prefer a "Slip-Fix" for this purpose along with "threaded" valves NOT slip (glued) valves.
In order to do this just make sure you dig a large enough pit area to route all the pipes in a logical and workable/fixable layout. Once buried the only thing that will show is the valve box and the valves will be inside the box - all those nice connections and pipe routing don't show under the ground. All the pipes and valves are water-proof and being in the dirt does not bother them.
BTW - Yes, I do this for a living - but in Florida - no freeze problems here.
/ Next Project - Lawn Irrigation #6
The gravel is the "floor" of the box. All pipes coming in/out of the box come in on the sides, and all the valves sit above the gravel floor. Nothing is below the gravel, so there shouldn't ever be a need to dig it up.
Thanks for the great feedback so far.
Here are some additional points in response to your questions. I am planning on pulling water from the lake and have already acquired the pump, intake screen, etc. I had a professional design done by a local Toro vendor and plan on installing the system by myself.
Some of my main questions are related to how best to situate the pump and associated output to the multiple zones that will be needed. I plan on doing the system in phases and so will need to plan for that when designing the output end.
Also, I will need to be able to easily disconnect the pump (electric and pipe fittings) to bring it in for the winter each year.
So, again - looking for ideas as well as pics / drawings on what has already been done by all the great members of TBN.
Keep the ideas coming!:thumbsup:
/ Next Project - Lawn Irrigation #8
Thomas,
We have 16 zones off a well that serves the house too. I learned the hard way - filter the irrgation too is my advise. Also normal installations have a "feeder line" from which the zones feed off. It sounds like you want to do a central manifold and feed from that? How many zones?
1. Water from the lake - this is fine, but I would dig a hole 3' back from the lake and install a 2' cement tiles - put the first one in then add a PT deck and then install a second tile above the water line with the top near ground level. This filters the water from the lake and you can put a PT or cement top on this.
2. With the pump "below" the yard for winterizing you can drain this out as part of the annual sprikler blow out. Also put a 1" filter on the output of the pump - this will save you many hours of cleaning valves and leaking valves.
3. Take pictures of the installation where the lines and wires run and map the solenoid boxes.
4. Install a lot of risers with hose/faucet connections. Its easy to do when you install it - later its not so easy to add a faucet..
5. Zone wiring, make sure you have at least 3 to 4 "free" wires in the cable that is run so if you are running say 10 zones, I would suggest running at least 12 conductors and 16 would be better in case you want to expand the system in the future. The reason for having "extras" is if one wire gets shorted/cut you can switch to another line.
6. Heads per zone and balanciing the pump output. Typical is 5-7 heads per zone and I would suggest you map the output of the pump to keep it running at its optimum and not turning on/off when irrigating - this will save you $ and increase pump life.
Carl
/ Next Project - Lawn Irrigation #9
One thing I learned is that a pipe puller is a far better way to go than trenching. Some places you really need a trench - like if you have a main trunk run where there are several pipes running together, but for single pipes - PULL them, don't trench! When I did mine 15 yrs ago a friend had his pipes pulled and I trenched mine myself. What a mess mine was. If you can't rent a vibratory pipe puller, people have reported good luck by using a subsoiler on the 3pt here, though I haven't tried it myself.
/ Next Project - Lawn Irrigation #10
This is good in theory. However, experience has taught me that in time the ground moves and that seemingly empty valve box ends up filled to the top with dirt and whatever else is in the box - if you put in gravel, it will eventually push the gravel into the box - been there, done that.
I agree with running spares in with the wires. If you are going to have many valves you may want to compare the cost difference of running multi-conductor wire or running several runs of single strand wire.
Multi-conductor will have several colors, one for each zone and white for common. If you run single-strand, they can all be the same color as long as you also run a white as a common. (if you try to run all single-strand runs in different colors it will cost more and they will eventually all look black in a few years)
Multi-strand comes inside a jacket that helps protect the wire. When you hook up a valve you will need to either cut the outer jacket and separate the color you want for that zone and the white for the common or cut and splice all the colors. Also, once you use a color there is no need to keep splicing or continuing that color to additional locations.
...normal installations have a "feeder line" from which the zones feed off. It sounds like you want to do a central manifold and feed from that? How many zones?
You can have a central manifold or "in-line" valves or a combination. Just be sure to bury your wires under the mainline (feeder line) and put any zone lines that share the same ditch above the mainline. By doing this, you will always be able to locate the mainline with a locating tool since the wire and mainline run together.
...Heads per zone and balancing the pump output. Typical is 5-7 heads per zone and I would suggest you map the output of the pump to keep it running at its optimum and not turning on/off when irrigating - this will save you $ and increase pump life.
Rather then counting "heads-per-zone" it is better to use "gallons-per-zone" to design the system. The final layout for zone purposes should be done after you have hooked up the pump and have done a flow test to determine how many gallons-per-minute your pump is delivering. Then you can lay out the zones and calculate the gallons for each zone.
It is correct that you do not want a pump to cycle while watering, but generally speaking, pumps that pull from a pond/lake do not use a pressure switch system. They use pump start and run each time a zone turns on. Since they run this way it is important that all the water they deliver is used for the system so that the excess water does not cause pressure to build. In a pump start system you should have a pressure relief valve that will allow the system to dump any un-used water.
A flow test is fairly simple and you can do one yourself - let me know if you need info on how to do this.
Your mainline and system size will vary depending on the flow. If you pump is delivering 15-20 gallons-per-minute a 1" mainline will be fine. However, if you system is producing 23-26 gallons-per-minute you will want to run 1 1/4" mainline.
The size of the mainline and flow will determine the size and number of zones. For instance, if you have a large grassy area you are watering with rotors and you have a flow for 1" mainline you could put 6 rotors with 3 gal nozzles on a zone (they come standard with a 3 gal nozzle) If you have a 1 1/4" mainline that same zone could have 8-9 rotors.
Spray heads also use various amounts of water depending on the nozzle installed - for instance a 15' half uses 2 gpm while a 12' half only uses 1 gpm.
I have not used a subsoiler or bottom plow to bury line yet, however, I have used the trencher, pipe-puller and ground saw.
The pipe-puller (vibratory puller) does leave a nice look when done. However, you have to dig a hole everywhere there needs to be a connection and they do not work well on new grass, in heavy roots or on lose dirt. Each pipe must be pulled separately - multiple pipes cannot be in the same ditch.
A trencher will go deeper then the other two methods but they are hard to control and heavy. They also do not do well in heavy roots or rocks.
A ground saw makes a nice ditch and will go through fairly heavy roots as well as rocks. However, they max out at 13" deep (great for here in Fl - but I am not sure about your area)
Also, when you make your zone runs, you can reduce pipe size as you use gallons. Say you have a 1" mainline and you have a zone with 6 rotors. If they are laid out so that 3 of them are along one ditch and the other 3 are in another ditch - each ditch only needs to be piped with 3/4" pipe.
Pipe capacity for irrigation (based on water running at 5' per second) is approximately as follows - at least these are the values we use - keep in mind that irrigation is usually run in "thin-wall" pvc not schedule 40. Schedule 40 runs less gpm since the inside hole is smaller.
1/2" - 6 gpm
3/4" - 9-11 gpm
1" - 18 gpm
1 1/4" - 28 gpm
1 1/2" - 36 gpm
Also, you can generally use a vale one size down from the mainline size. For a 1 1/4" mainline you can use 1" valves - they even make male adapters that are 1 1/4" slip by 1" thread. Same goes for 1 1/2" mainline.
For 1" mainline I would stick with the 1" valves as 3/4" valves (yes, they do make them) seem to cost more then the 1" ones.
Also, you should never combine rotors and sprays on the same zone. They use water at different rates.
A spray delivers water to the entire patterned area the whole time it is running. Say a 15' quarter-circle. This means that the entire area covered by the head is getting watered the entire time it is spraying.
A rotor, on the other hand, only waters the area it is pointing at while it is rotating. So, to cover the same quarter circle with the same precipitation rate as a spray it will need to run longer (we use a 3/1 ratio - if a sprays run 15 minutes we run the rotors for 45 minutes.
You might ask why one would use rotors if they need to run longer - 15' is the largest fixed spray usually used while a rotor can cover 45' with proper water pressure. Sprays are used for plated beds and small area while rotors are used for larger open areas.
/ Next Project - Lawn Irrigation #11
The system just passed 12 years old, and all the boxes still look great. I wouldn't hesitate to do this again.
/ Next Project - Lawn Irrigation #12
I'm glad it has worked for you. Just think, if after 12 years the box still looks good, and there has been no earth shift that has caused the level of dirt in the box rise, how much nicer it would be if that gravel was not in the bottom. It would look just as good without the rocks.
I will also say that even here in Florida where I have dug up vast numbers of valves several years in the ground, I have, on occasion, dug some up that were not filled with dirt. This has been the exception rather then the rule. By far, most of the boxes I have dealt with have filled over several years. Every time it rains and the valve boxes fill with water some dirt comes in. Normal earth movement also pushes dirt into the boxes.
I guess in a more rocky region of the country there may not be as much movement as here in Fl, but I still don't like to do work that is not needed and gravel in the box does nothing to enhance the irrigation system so why bother with the time, work and experience?
