Buying...help! L3800 or Bx3200
/ Buying...help! L3800 or Bx3200 #1
hnicols
Member
Upstate, NY
Yanmar Lx 4900
Looking for my first tractor. Use: 100acres mostly wooded, 800 ft gravel driveway, pond that occasionally needs clearing, 5acres for pasture/ brush hog, fertilizer and seeding. Lots of logging roads that could use some help. I think the too wet and soft to use tractor on 4 acres of lawn that need mowing and have a guy who does that cheap for me. Don't really see to much need for a backhoe but suspect if I had one....
If pay cash have following alternatives before tax
New L3800 TLB HST 27,200
New Bx3200 TLB HST. 25,222
used not from dealer 2007 L3400 TLB HST with old flail mower, leveling box, posthole digger and rake for 23000
Could use the attachments thoughthey are appropriately worn. Hate to go without warranty on my first tractor though.
Thoughts?
/ Buying...help! L3800 or Bx3200 #2
Hey there and welcome to TBN (again) ;).
What happened to the B3030hsd in 2005?
Personally I would (actually I did) opt for the L3800. It is not much more money but a much sturdier machine and of course many more horses under the hood. E.g. look at the front axle of the B-Series tractor and compare to the L3800. Huge difference! Especially when planing to go into the woods. Also the L-Series are wider, which gives you more stability.
Be aware though of the 'jerky' 3 point hitch (search this forum). Mine does the jerky thing too, but not too bad. You gotta check this out at the dealer and decide for yourself.
I had the same concerns about new tractor versus used. I went with a new because of the warranty (and since I was new to the business, I didn't exactly know what to look for/check on a used tractor).
Go test drive both if you like and judge for yourself.
Good luck.
Life is what happened to the b3030. Got caught up with work and never purchased. Now I have retired and want to play. Glad you like the l3800. Think I am headed in that direction but pains me to buy new as so expensive, especially since I worry I will use at most 100 hours a year. But like having the warranty that the dealer tells me almost never gets used. How bad is the 3pt hitch problem? Is it worth my looking to Deere or someone else? Deere is so expensive, almost 6k more for something comparable.
/ Buying...help! L3800 or Bx3200 #4
with 100 acres I would go with the L3800 between those two. But if it was me I would get a much bigger tractor, a MX5100 at the very least but preferably a M.
And with a 800 ft driveway in upstate NY a snowblower would top my ''to buy '' list as attachment goes.
/ Buying...help! L3800 or Bx3200 #5
I agree with the snow blower 100%, unless you've already got a blade mounted to a pickup.
With 5 acres to rough cut and a pond to maintain, either the L3800 or the L3400 seem a perfect fit.
With Kubota's current financing, I'd use their money, in any event.
Thanks all. I hear you on the snow blower except there are so many people here with plows on pickup that snow plowing is pretty cheap and since my wife and I travel some I need to rely on them in any event. If I was going for snow blower wouldn't I then want a mid pto so it is front mounted? Doesn't that suggest the b3200?
I like the financing but they will also give me a 1500 discount for paying cash. Since my money is currently earning close to zero percent I thought I would go with the discount.
/ Buying...help! L3800 or Bx3200 #7
If you go to the Grand L series you can get a mid PTO and a front mount 62" snowblower.
With the amount of pasture you need to cut, I think bigger is better. If you go to a Grand L series you get a longer wheel base heavier tractor that would be better for brush mowing, loader use, backhoe use, could have a front mount blower, or MMM, and won't have a jerky hitch.
Tractors tend to shrink with use. If you can afford to, I would advise going a little larger than you think you need. Features like mid PTO can be added later if you want, but they can only be added to machines that would except them in the first place.
IMHO a B series would be good if you also needed to mow your lawn, but limited for other tasks. They are very good tractors that can do many things, but like all tractors they are limited by their size and weight. If you need to work in a confined area they are great. If you don't then bigger (to a point) is better.
Happy hunting, Bill:D
/ Buying...help! L3800 or Bx3200 #8
If you go to the Grand L series you can get a mid PTO and...
I would also suggest this... the Grand L features would be a nice retirement gift to yourself :thumbsup:
Take your time with buying and get what you need. A backhoe seems to me to be pricey... for what I do, front forks, grapple on the bucket and other attachments allow my tractor to do a lot (for just a little extra money).
You should look at other models - that's half the fun when buying. Definitely test out the 3 point hitch.
/ Buying...help! L3800 or Bx3200 #9
On the snowblower end we often go to a three point hitch to deal with the banks that the plows leave. When we do get a big fall it is not totally unbearable to have it on the rear as long a you get an auxilary valve for hdraulic turn!
When needed in the past you can often guide by the old existing plowing to get the driveway open and not even looking back for much of the distance or to use the loader to bunch it, then blow the banks away.
So you could get by with a MX series without the mid PTO.
I'd also recommend the larger series with ag or r-4 tires. The backhoe could help with the wet issues with possible trenching or ditching or tile.
Grand L's do give you some good features like the mid PTO but with the price difference you could buy some extra tools!
The B-3200 could do but the L would be better, it depends on you!
/ Buying...help! L3800 or Bx3200 #10
you can often guide by the old existing plowing to get the driveway open and not even looking back for much of the distance .
Your not missing any dogs or cats, are you?:shocked:
Things happen fast. I wouldn't advise traveling any distance without looking where your going, especially with something like a snow blower.
Bill
/ Buying...help! L3800 or Bx3200 #11
I have the L3800 with BH77 and 66" QA bucket. I love it and use it for your same intended use. You will NOT have any regrets as long as you can get the 3pt jerk adjusted by your dealer. Get Kubota's rep involved as it knows how to make it right. Problem is your dealer probably won't touch it until you buy it. I suggest you make it a condition before you buy. A good test to see how well the dealer values you as a customer. The situation sucks, but the adjusted valve makes the L3800 a worthy investment. The tractor is solid. You can't go wrong with a Grand L either...just more cash.
Thanks! How does grand differ from l series beyond mid pto wheel base and weight? I get the mid pto value if I snow blow, but again I have good people who do 800 foot of drive cheap, like $65 a throw, and very well. Spending my time at 15 below to 15 above seems pretty harsh as i rarely have more then 12 real snows a year ( last year only five!) if i figure 700 a year for plowing, and a snow blower costs north of 5k, it takes a reAl long time to recover snow blower costs. Even ignoring time and fuel. I think I just have an anomaly in the Adirondacks of lots of people with trucks and plows who need money.
Are there other reasons I would want a mid pto? If not, seems like a big step in price to go for the Grand if the L3800 would also get job done.
Keep the advice coming! Thanks.
/ Buying...help! L3800 or Bx3200 #13
One point I would disagree with you on, is buying first on the hopes that it will be fixed. The adjusted valves I have read about on this forum tend to have side effects. The 3PH is smooth, but will drop, then recover when the FEL is operated. Do a search and you will see what I mean.
Once you buy the tractor it's yours! Even with a agreed condition, you could have a fight on your hands.
I would advise anyone, if you don't like the jerky hitch, get a different tractor. As far as Kubota is concerned, that's the way they were designed to work.
Bill
/ Buying...help! L3800 or Bx3200 #14
I am not advising you to get a snow blower attachment, instead of having someone plow for you. I was answering your question in your earlier post.
"If I was going for snow blower wouldn't I then want a mid pto so it is front mounted? Doesn't that suggest the b3200?"
Wheelbase and weight makes a big difference in a tractor. The smallest Grand L is the L3240. It is very close in size and weight to a L4600, with alot more features. I suggest you go to the Kubota site and compare.
As far as the jerky hitch goes, it was very important to me, enough to kill a sale.
If you don't care about the jerky, and some people don't care, that's OK. I just want you to be aware of it.
I don't own any Kubota stock, so it doesn't matter to me if you buy a Deere, IH, or NH.:D You should get what suits you.:thumbsup:
Best, Bill
2016 Chevrolet Caprice Sedan (A61569)
2016 Chevrolet...
2011 AUXILIARY POWER UNIT (A60736)
2011 AUXILIARY...
2018 Ford E-450 Shuttle Bus (A61568)
2018 Ford E-450...
HEAVYEQUIPMENT TOOLS (A60736)
HEAVYEQUIPMENT...
2014 18ft. Top Hat T/A Trash Trailer (A60352)
2014 18ft. Top Hat...
2014 AMERITRAIL LAY FLAT HOSE TUGGER TRAILER (A58214)
2014 AMERITRAIL...
