M7040 Throttle Adjustment
/ M7040 Throttle Adjustment #1
rwskinner
South Texas
2011 M7040-DTC (4x4 CAB)
My 7040 has a little over a hundred hours on it and the hand throttle slowly backs off while using the machine. Before I start tearing stuff apart, is there a friction adjustment on it? Is it easy to get to?
Thanks
Richard
/ M7040 Throttle Adjustment #2
Thanks
Richard
With that few hours it should be a warranty matter. Let the dealer deal with it. The dealer should send out a mechanic rather than requiring you to haul in the tractor.
/ M7040 Throttle Adjustment #3
Hi Richard.
I havnt notice any problem with this on my m7040.
It must by fairly easy to fix it. Friction-wise, I think you feel it by testing what works for you. Good luck.
/Sam
/ M7040 Throttle Adjustment #4
Yep, I would leave it up to the dealer myself.
I'm sure it is an easy fix, I was just asking if anyone had to do this and what was involved. I'll tear off the side panel and see if there is a screw and washer that can tighten the friction.
I also know the detent on my remote valve works fine in one direction but doesn't lock very well in the other direction.
Richard
/ M7040 Throttle Adjustment #6
Let us know what you find out.
Deutz D3006 Tractor (A62613)
Deutz D3006...
2008 CATERPILLAR D4K XL CRAWLER DOZER (A64279)
2008 CATERPILLAR...
2007 Ford Crown Victoria Sedan (A61574)
2007 Ford Crown...
2012 POLAR TANK TRAILER (A63569)
2012 POLAR TANK...
John Deere 2155 (A62177)
John Deere 2155...
2004 International 4300 Fuel & Lube Truck 593775 (A62613)
2004 International...
