Did a little hay last week ...
   / Did a little hay last week ...
Well just figured would show a couple pictures of the square baler I picked it up finally and went over the whole thing top to bottum,spraying greasing,washed it:D,it turns really good by hand.
View attachment 268185View attachment 268186View attachment 268187View attachment 268188
Nice job ... it looks good. I put used motor oil all over the inside plunger chamber ... and made sure all rollers are working....crawled in and used the hand grinder to touch the knives up as well.
   / Did a little hay last week ... #232
The inside of everything looks great,all the sprockets,chains,etc. I knew the guy selling it and he told me it hasnt ever really been used,by the looks of it,it hasnt baled much at all. The only thing was it setting outside for a couple years has some rusty spots. I get some free time,my do a liquid over-haul this winter....
   / Did a little hay last week ... #233
On another TBN post a guy lists the 315 as mfg between: 315 NH SQUARE BALER (8/76-4/82) http://www.tractorbynet.com/forums/attachments/146796-new-holland-baler-haybine-numbers.html
Did you find a serial number?
It really doesn't matter if you can get parts.
Too bad the horse lady in MD didn't find one of those in the weeds with the
mowers and other stuff. Would her tractor handle a baler that size?
When are you going to try it out in the field?
Ron
   / Did a little hay last week ... #234
13 acres at the house and farm all rolled up and sold. Nice to have 2 tractors one for cutting and baling and one for raking. If there is a second cut i will square bale it . If we get rain .
Nice ... Is that sickle mower New Holland 9'? Good looking tractors ... the 2000 looks real good!
   / Did a little hay last week ... #236
If it is a New Holland Mower is that a homemade curl plate on the outboard end?
I've got the old bent rod type that is two rods bent to make four springy
sections. I kept loosing them and the front holding plate in the field and praying the round baler didn't pick them up, so years ago I drilled and cottered past the nuts as well as using Nylock nuts.
which fixed that. The rods still liked to break off periodically from all the vibration, so I added a couple plates to hold them together further back. Still break one occasionally. You'd think something bright yellow would be easy to find in green/blue hay but it's not. I even tied red survey tape on the tips one year. Never have found the broken pieces in the fields and never in the hay. No one has ever called finding one in the ones sold either.
Biggest thing I hate now is I'm always poking my head into the end of one when I'm hooking the mower on or off the tractor in the fold up position.
Always looking for ideas to improve stuff.
Ron
   / Did a little hay last week ... #237
Ron
Gonna put it to use right after these cple rains were suppost to get and if we dont get the rain then it will be sooner.
I did see the serial number plate and were it was sold on the side but didnt right it down. It was sold at the same place I bought my Kubota witch sold NH back then:DThey did sell different balers until there was some kinda firer at there shop years ago and stopped carrying them,but they carry everything else.
FarmBoy what kinda baler you running?
Well I didn't notice that swath board until you pointed it out ... it looks like its oak and somehow its been hollowed ... gotta be a factory option?
Hope he gets back in and tells us more !!
   / Did a little hay last week ... #239
What do your square bales weight you sale?
I have a scientific measuring system .... pick it up and say "yep its 60-65 Lbs"
I have never weighed one ... I just call them 60-65 lbs and then when a buyer picks them up and says "yep they are good" well that proves my method works!!!
I make a 35" bale ... works best in my accumulator and grapple system ... stacks very well on the trailers and in the barn ... now again this is pure farm science ... some may get a little longer or shorter. Windrow consistancy is important as well as speed ... if the hay gets light I shift up to get more going into the baler and then shift down when it gets thicker.
UNUSED FUTURE 16" AUGER (A57193)
UNUSED FUTURE 16"...
UNUSED PABREAK SP173-84" SNOW PUSHER (A57193)
UNUSED PABREAK...
2025 Swict 66in Bucket Skid Steer Attachment (A55851)
2025 Swict 66in...
JOHN DEERE 5115M TRACTOR (A51243)
JOHN DEERE 5115M...
UNUSED FUTURE 40" HYD TILTING BUCKET (A52706)
UNUSED FUTURE 40"...
2014 Chrysler 300C Sedan (A55853)
2014 Chrysler 300C...
