Boy did I Just do a Stupid Thing!
   / Boy did I Just do a Stupid Thing! #21
I've driven mine into the face of my garage like that probably three times. Fortunately for me, the eave / soffit is high enough that the ROPS completely clears all of that and only smacks the face. My lot is almost perfectly level, so I don't waste my time putting up the ROPS unless I'm using the FEL with some weighted stuff (gravel, log length firewood, or even mulch). I'm going to be building a large shed and will install an 8' overhead door to accommodate the ROPS. If I end up adding on to the garage, I'll be sure that an 8' door goes there as well.
   / Boy did I Just do a Stupid Thing! #22
Better make that a ten ft. door......never Know!
   / Boy did I Just do a Stupid Thing! #23
I almost do this everytime i put my tractor away. I finally hung a sign down off my garage door opener. It says ROPS?
   / Boy did I Just do a Stupid Thing! #24
don't feel so bad a couple years ago i tore the front off my barn backing into scrape the stalls out had to replace the facecia boards 4 pieces of metal and 4 2x4 it just happens hope it don't get in your pocket to bad.
   / Boy did I Just do a Stupid Thing! #25
Just going to say the same thing. My tractor ROPS is just over 8 ft high.
   / Boy did I Just do a Stupid Thing! #26
When I was a kid, we had our septic tank replaced and they dug up the entire front yard doing it. Rather than pay someone to grade it, or maybe just because he thought it would be fun, my dad rented a skid-steer-loader and decided he'd do it himself. The story he tells from that event goes like this:
"The loader has one lever, and you push it and it turns left. It has another lever, and you push it and it turns right. And if you push both levers, the thing swings right around and takes the porch right off the front of your house."
Yup, he knocked the porch off the house because the loader swung around quicker than he expected.
The other story from that event is, he was trying to grade the yard, backdragging, you know, and a pickup truck that's driving by stops and the driver gets out and just kind of stands there for a while watching my dad work. Finally, the guy yells to him, "Hey mister! You're ruining your yard!" Turns out the guy was an operator and gave him a few tips.
I think of those stories often now that I've got a tractor of my own.
   / Boy did I Just do a Stupid Thing! #27
I've ran mine into the shed I part in 4-5 times. It's normally late and after dark. I just want to get it in and go inside. I haven't done any damage yet. The shed is just temporary until I build a barn. So no harm done. Once I hit it hard enough I thought I might have hurt something. Good thing ROPS are strong.
   / Boy did I Just do a Stupid Thing! #28
I measured mine and it will definitely fit under an 8' door. Also, there's no "chance" of my getting a larger machine while I live here, so I'm good. :)
Strong? You aren't kidding. One of the times I hit my garage wall, I made contact with only one side because I was at a bit of an angle. The noise that it made sounded like the header was being pulled out from above the door, and it actually transferred the force down into my fender and caused it to actually bend a little (no crease, just a slight bend).
   / Boy did I Just do a Stupid Thing! #29
didn't read every post here, but just the title and first post quick read made me laugh. sorry about your misfortune. it is probably only a matter of time before i do the samething. onetime i came back home from bush hogging and it was late and i was tired i pulled up to the door with the tractor and for whatever reason i stopped, got off to get something, and when i looked back, i stopped no more then an inch away from the rops hitting just about the same area. i am not kidding, it was close and if i didn't stop at that moment or look at the tractor before i got back on....
another story real quick. where i work at the state transportation dept, the garage door openings aren't quite tall enough to fit the back hoes through with the back boom in the transport position. have to lower it down just a bit, then come through. building is brick/block and i bet you know where this one is headed. it wasn't me that did it, it was a seasoned operator, so it can happen to anyone. i have even watched operators at the golf course i use to work at, hit tree branches with the rops and pick the front of the mower up.:confused2: good luck with your repairs.
   / Boy did I Just do a Stupid Thing! #30
Pulled tractor into garage without lowering the ROPS. Wife said the whole house shook. Tore out the eave and broke the faceplate on the front of the garage. Nice!
Been there...done that...I didn't do as much damage luckily.
30007 (A53424)
30007 (A53424)
2003 McCormick XTX 185 XtraSpeed Tractor (A55302)
2003 McCormick XTX...
JOHN DEERE 3020 TRACTOR (A51247)
JOHN DEERE 3020...
2011 EAGER BEAVER 35G SL DETACH TRAILER (A52706)
2011 EAGER BEAVER...
2001 CATERPILLAR 420D BACKHOE (A52707)
2001 CATERPILLAR...
2007 FREIGHTLINER COLUMBIA 120 (A55745)
2007 FREIGHTLINER...
