BX25 pallet forks
/ BX25 pallet forks #1
Yooperman
Member
Kubota BX25
Pictures of my first major BX25 project... pallet forks. If I said it once, I've said it a thousand times... I LOVE that tractor! :laughing:
/ BX25 pallet forks #5
nice design!:thumbsup: I have a question tho. do you have difficulty in trying to install the pins with guard up that high?
/ BX25 pallet forks
93Mustang - I took my welding class at the local vocational technical school that offered classes in the evenings. Highly recommended.
radioman - I am afraid I do not totally understand your question. I have no trouble with the pins. Perhaps an additional picture will help make it clearer.
/ BX25 pallet forks #7
Beautiful work! I'm wondering if it's possible to mount pallet forks to my chain hooks on my bucket? Any thoughts or suggestions appreciated!
/ BX25 pallet forks
Thanks. I've seen forks that attach to the FEL bucket. I do not think the chain hooks were used in any way. Using FEL bucket forks would make putting them on quicker, but I am sure they could not lift as much weight. And, personally, I'd be concerned with bending the bucket where they attach from trying to lift too much weight. Good luck.
/ BX25 pallet forks #9
Hi Yooperman,
Your forks are the best I've seen. Kudos on the Kubota forks.... I was looking at the last picture you show with the detail of your attachment point. What are the details for the weld where the PIN goes through the mount point on the U channel for the hydraulic arms on the BX25?
Thank in advance..Ron
/ BX25 pallet forks
Thanks for the kind words. If I remember correctly, I took the placement for the mount point directly off the FEL bucket. In other words, I measured the distances on the bucket and just replicated them for the forks.
If that doesn't answer your question, I'll try again.
/ BX25 pallet forks #11
Thanks for the reply. I attached a picture (I hope) of the area that I am curious about. I was wondering what you used for this? Is it a small piece of steel pipe welded to the side of the mount for the mounting PIN to go through and a hole drilled in the side of the pipe for the clevis pin to go through? Thanks again.......
/ BX25 pallet forks #12
Bxpanded.com makes themm. Very quick on and off.
/ BX25 pallet forks
That is exactly what it is. I was lucky enough to find pipe with an undersized hole so that enlarging it for the pin was fairly easy. By far the hardest thing for me to do was to drill the hole in the pipe for the clevis so that it was exactly centered so as to line up with the hole in the attachment pin.
/ BX25 pallet forks #15
Nice job. I need to make something like that for my B2320. Do you have an idea on how much it weighs? Would you mind sharing a few details, like material sizes you used,etc. Not necessarily the cut lengths, but things like 2x2x1/4 tubing for fork top rail mount, 3x?# C-channel for uprights and forks, etc.
Thanks
/ BX25 pallet forks #16
I was just thinking about the problem of getting the hole lined up. Your picture made me wonder if you could start with a hole on one side of the tube, then insert the pin and use the drill bit to get the 2 holes aligned, then drill thru the other side while the pin is still in place. Seems like that would solve the problem, but I haven't tried it. You would essentially be using the pin as a drill guide.
A v block that is carefully setup on a drill press will hold round piece in place as well, and is a good place to start to get the first hole aligned. I've always found it is hard to get that first hole to start straight thru, seems like it always wants to wander a bit, even if (or maybe because) it has been center punched first. If everything is set up right the hole should go dead center thru both sides. Of course, this works best with longer pieces of stock so there is enough to clamp into the v block. Also, I think it might work better to get the hole started if a center drill is used without center punching, just rely on the setup to have the workpiece center under the bit. Center drills are short and very rigid, which helps eliminate any tendency for the bit to wander.
Sorry, I was just thinking this through and writing it out helped me to visualize. Maybe my musings will help someone else, or maybe someone will point out the fallacies of thinking. I've been without a shop for about 3 years and am getting out of practice on this stuff. Need to get a building up this year so I have a place to work again.
2014 BMW X3 AWD SUV (A61569)
2014 BMW X3 AWD...
(10) Belts for Round Bale Cotton Picker (A62177)
(10) Belts for...
2018 International HX620 Quint Dump (A62613)
2018 International...
2014 Chevrolet Cruze Sedan (A61569)
2014 Chevrolet...
New/Unused Landhonor Quick Attach Pallet Forks (A61166)
New/Unused...
2014 John Deere 350G Hydraulic Excavator (A60352)
2014 John Deere...
