Grand L5740 3 pt will not lower
   / Grand L5740 3 pt will not lower #1
bucktaker
Sw Ohio
Kubota L5740
Hey gents my L5740 has the 3 pt all the way up and will not go down. The lever is connected under the seat area. I hve no draft control or rear hyd outlets. I was too hot do much other than look today but anyone have any ideas
   / Grand L5740 3 pt will not lower #2
I am assuming you know about the drop rate valve between yours legs under the seat. Make sure it is open.:thumbsup:
   / Grand L5740 3 pt will not lower #3
Here is the 3 point flow control knob. Make sure it is in the full open position. Philip.
thanks that was it i must have moved that valve getting on or off:thumbsup:
2018 Genie GTH-636 6,000LB 4x4 Rough Terrain Telehandler (A46683)
2018 Genie GTH-636...
300 Gallon Tote (A49251)
300 Gallon Tote...
John Deere 1240 Corn Planter (A49251)
John Deere 1240...
Deutz F3L 912 2WD Utility Tractor (A49346)
Deutz F3L 912 2WD...
2013 PETERBILT 337 CAB AND CHASSIS (A48992)
2013 PETERBILT 337...
1999 Volvo VN Truck, VIN # 4VA7BBJF9XN770848 (A48836)
1999 Volvo VN...
