Buying Advice M9540 On The Way
   / M9540 On The Way #11
Good job on getting the 12 speed! I always thought if I bought a cab tractor I'd tint the windows. :thumbsup:
   / M9540 On The Way
Charley, meant to say I looked at a new CaseIH Farmall 95.
   / M9540 On The Way #13
Thanks Bluegill and Foreman, I appreciate it, hope its the last one I ever have to buy, I drove myself nuts making the decision as I'm sure everyone does. :thumbsup:
Yes sir,just ask TripleR he helped me a bunch,and I didnt end up buying,bought new hay equipment instead,new tractor will have to wait.
The 9540 is the one I also had picked out....M100 is my I wish tractor...
   / M9540 On The Way #14
Is there anything else you gents can think of that I should consider?. Adios
Depending on what implements you will be using, but you might want to consider getting the 3rd rear remote. You can never have enough remotes. ;)
   / M9540 On The Way #15
Congrats Texasbest!! I know you will love the Kubota, and it sounds like you got all the good stuff.
Charlie
   / M9540 On The Way #16
I just got a M7040... and love it.
Go ahead and get the 3 remote.... The $800 ish you spend now will be worht it down the line
Welcome to the orange side..
   / M9540 On The Way #17
Not sure if what is being referred to here is the window tint film or not, but if that is what you are considering, keep in mind that there should be no restrictions (as there might be for a motor vehicle operated on the road) - you can use any type.
I understand that the silver reflective tint has the highest rejection of infrared radiation .... :thumbsup:
   / M9540 On The Way
Yessir I was referring to the film, it is great in a pickup to reflect heat and glare, my concern on a tractor would be reduced visibility, but I guess the same logic applies to a pickup, bottom line is I will probably get it done unless someone convinces me otherwise!
   / M9540 On The Way #19
Great choice on tractor. I will baling hay with my m9540 tomorrow in 90 degree heat no tint will see how it handles the heat so far no problems cab stays cool with fan setting staying on two kick up to three when reentering the cab then down to two again. That was all in high 80's low 90's.
   / M9540 On The Way
Good deal Zscoop, let me know how it does tomorrow baling, the only reference I have with the A/C was in the dealers lot and it didnt get real cool, but I also realize it cools better when the RPMs are up and it is moving. :thumbsup:
2016 VOLVO VNL300 TANDEM AXLE DAY CAB (A51222)
2016 VOLVO VNL300...
2003 Pierce Fire Truck (A50323)
2003 Pierce Fire...
2018 FORD EXPEDITION (A51406)
2018 FORD...
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
71050 (A49346)
71050 (A49346)
2001 STERLING WATER TRUCK (A51243)
2001 STERLING...
