If you had a choice
/ If you had a choice #22
My acetylene bottle lasts a LOOOOOOONG time. I May have sticker shock when I need to refill it since it has been over a year since my last acetylene refill but I would go for an OA rig and have a propane cutting tip available for standby on a propane bottle, assuming that you have a few BBQ propane tanks around. Cheap investment to have both available for around $10 more just in case. Since O2 goes faster I have a spare O2 bottle but not acetylene all of which I picked up on CL but note the precautions that have been discussed when buying of Craigslist as many sellers dont actually own their bottles which you will find out when trying to refill them.
/ If you had a choice #23
The ownership of compressed gas bottles is about as clear as owning a CDL!
David from jax
/ If you had a choice #24
I'm with the others who suggest you should consider a horizontal band saw. I LOVE mine. When I bought it I already had a Milkwaukee chop saw and a oxy/fuel rig. I use the band saw far more than I use the torch, and I sold the chop saw because I hadn't used it once in the year after I bought the band saw.
It really comes down to this... How may curved cuts do you need to make? You can make straight cuts with a torch, but you can't do curved cuts with a band saw. You can fake it with an angle grinder if you take a lot of time, though.
Regarding the MIG welder... the only advantage I've seen for a MIG over a stick welder is very thin metal. Keep the stick and practice more.
/ If you had a choice #25
I have one of the HF cold saws and I dont even use my abrasive chop saw any more. I can cut a piece of 1/2 x 4" bar stock in less than a minute. I wish HF made a chop saw type cold saw. Highly recommend this type of metal cutting saw.:thumbsup:
/ If you had a choice #26
I love my plasma it's sooooo! Easy . Saying that the torch is more versatile of you already have a stick welder and you mainly weld heavier metal than the mig would be my 3 rd choice plasma or oa I think I'd go oxy /ac and save for a really good plasma cutter
/ If you had a choice #27
Heavy Duty Booster Cables (A64557)
Heavy Duty Booster...
2025 IRET13 Electric Tricycle (A64194)
2025 IRET13...
18 FOOT WATER/FUEL TRAILER (A67714)
18 FOOT WATER/FUEL...
HELI 5K FORKLIFT (A67714)
HELI 5K FORKLIFT...
PORTA POTTY (A68842)
2010 RU SYSTEMS SMART 850 SIGN TRAILER (A66091)
2010 RU SYSTEMS...
