Comparison Kubota L4600 or Mahindra 4035
   / Kubota L4600 or Mahindra 4035 #1
JHubbs
Prairieville, Louisiana
None
Trying to pick from the Kubota L4600 or the Mahindra 4035 (both 4x4 with FEL). I want to use 6 foot implements, bush hog, maintain a gravel road, spread dirt and keep up about 300 acres of hunting property. The L4600 has a bigger engine (46 HP) but the 4035 has stronger FEL and is heavier. Thanks for the input.
   / Kubota L4600 or Mahindra 4035 #2
You will get more done with the 4035. HP isn't everything and from the sound of what you want to do, weight and hydraulic capacity will be your friend. Maybe consider one of the Grand L Kubotas, maybe an L3940 or a L4240, the 4035 is still quite a bit heavier though.
Thanks for your input. Yes, weight is one of the things I am considering. I have a half ton Chevy and will be maxing it out once I add a trailer and an implement. I saw the 4035 weighs over 5000 lbs with FEL. Thats a beast, for only a 40 HP tractor!
   / Kubota L4600 or Mahindra 4035 #4
If you are going to be transporting on a regular basis, then maybe lighter would work out better for you. The heavier machine is going to get more work done for you, but if you can't get it there, it's not going to do you much good.
My little Mahindra 3215 tips the scales at 5000 lbs with water in the tires, the loader and a heavy box blade. Power to spare, I doubt that you would have any power problems with the 4035 unless you are over sizing some of the implements. Stay with 6 foot stuff and you will be about unstoppable.
If you are going to be doing much grading, be sure to get at least 2 rear remotes so that you can add Top and Tilt cylinders to the 3pt so that your grading comes out much better and easier. ;)
   / Kubota L4600 or Mahindra 4035 #5
For what you have planned, weight will not be an issue. If anything if you have to transport the tractor it'll actually hinder you more than help.
   / Kubota L4600 or Mahindra 4035 #6
i would say fel cap and the weight will help so the mahindra would be better then kubota i have a L3800 WITH 14 HRS ON IT ITS TO LIGHT A 5000IBS TRACTORS NOTHING TO TRANSPORT I PULL 12-13K WITH MY 1 TON SINGLE WHEEL WITH A GAS ENGINE
   / Kubota L4600 or Mahindra 4035 #7
That's good for you.
But a "half ton Chevy", say a 2001 1500 w/ a V6 may only be rated for 6,000 lbs or less. A 5,000 lb tractor, an implement, chains, fuel, and a trailer will surely push that.
   / Kubota L4600 or Mahindra 4035 #9
If its hilly I'd recommend loading the rear tires too, so add some more weight for that. "Spreading dirt" I imagine soon equals digging dirt and you'll never regret having a heavier tractor for dirt work. And a good box blade adds 700-1000lbs more too.
Maybe spend what you saved buying the Mahindra on either a really light trailer or upgrading your truck?
   / Kubota L4600 or Mahindra 4035 #10
If you are set on keeping your current truck and trailer, then look for a tractor that will fit in your capacities, otherwise bigger might be better for you and your circumstances. ;)
2012 VOLVO VNL TANDEM AXLE SLEEPER (A50046)
2012 VOLVO VNL...
2014 Harvestec 6306 (A47164)
2014 Harvestec...
FIFTH WHEEL HITCHES W/FENDERS (A48992)
FIFTH WHEEL...
2008 Ford F-250 Reading Service Truck (A48081)
2008 Ford F-250...
2018 INTERNATIONAL 4300 26FT BOX TRUCK (A50046)
2018 INTERNATIONAL...
2022 Chevrolet Tahoe FL SUV (A48082)
2022 Chevrolet...
