Square Bales for Horses
/ Square Bales for Horses #1
LongRunFarm
Marshville, NC
JD 3320
There are 16 acres to mow, tedder, rake and square bale. I have a JD 3320 which has 25 HP at the PTO. Trying to find the equipment is difficult because there are not standard HP listings. They don't always deferentiate between Tractor HP and PTO HP. Would like information about tedder, rake and square balers that I can run with my tractor.
/ Square Bales for Horses #2
You might be better off finding a local already in the hay baling business. Work out some deal where you get what you need for the year and he can keep what's left.
25HP isn't really enough for a square baler, need more like 40-50HP generally.
/ Square Bales for Horses #3
I agree 25hp is not enough for a baler. You might find an old baler with it's own engine but I would only consider that if your ground is pretty flat. You don't have enough tractor for hills.
/ Square Bales for Horses #4
ALL balers are spec'd to PTO horsepower. Remember to consider if your tractor is heavy enough. That is a bigger concern, more than HP. Baled with an MF 35, and it fit the bill nicely.
/ Square Bales for Horses #5
Some tedders and rakes are ground driven, so your tractor PTO hp is a non-issue. Others are pto driven. Smaller ones can run off 25 hp.
Small square balers like my Massey Ferguson 124 are speced at 35-40 hp pto. But you can run them with smaller tractors. Here's a YouTube video showing a small square baler being run by a Farmall Super A that has less than 20 hp pto.
[ame=http://www.youtube.com/watch?v=Cvz8-Sw1ntA]FARMALL Super A - YouTube[/ame]
The baler part starts about 6 minutes into the video.
You might find an old square baler with an on-board Wisconsin air-cooled engine so you don't have to power the baler via your tractor's pto.
Good luck.
/ Square Bales for Horses #7
I know where one of those can be found, but it might be a long ride form NC to NY.
Aaron Z
2015 Kubota RTVX1100C (A62177)
2015 Kubota...
2018 HINO SA (A58214)
2016 JOHN DEERE 310L BACKHOE (A62129)
2016 JOHN DEERE...
(2) 30 Yard Roll Off Dumpsters (A61165)
(2) 30 Yard Roll...
UNUSED RAYTREE REDM32 - 32" HYD EXCAVATOR MULCHER (A62131)
UNUSED RAYTREE...
2021 FREIGHTLINER M2 106 S/A 4X2 24FT BOX TRUCK (A59909)
2021 FREIGHTLINER...
