HST Creep on Slope
/ HST Creep on Slope #1
British Columbia
Kubota L4740HSTC
I'm only 14 hours in with my new L4740 cab w backhoe and loader and have noticed the tractor will creep forward or reverse (depending on slope) after I have removed my foot from the hst pedal. I don't think it did this back at 3 hours. Just wondering if this is normal. Thanks
/ HST Creep on Slope #2
any hst i have run will slowly coast downhill when in neutral and parking brake off. the more slope the faster the coast. still better then a gear shift in neutral, that would free wheel bad. also different hst will coast more or less then others.
/ HST Creep on Slope #3
Normal operation. They all do it.
James K0UA
/ HST Creep on Slope #4
My Kioti DK35Se HST rolls on the hills unlike my mahindra 2810 HST. why? who knows .. . Guess thats why they put a parking brake on them . . .John
Thanks John! I just love it when I set out too do something and when its done there is still time and energy to do more. I should have bought a tractor 10 years ago.
/ HST Creep on Slope #8
Mine, when it was new, would hold on a very gentle slope.....now, will very, very slowly creep forward/reverse depending on slope direction and amount. So, my conclusion is that as a tractor breaks in a small amount of creep is typical.
/ HST Creep on Slope #9
Normal for the HSTs, I have driven.
/ HST Creep on Slope #10
Just a heads up to all HST owners. Supposedly if you leave the engine off and the brake off the HST will creep forward and pump the oil out of the HST and allow it to then freewheel (or nearly so). I have only read about this but thought it was worth a mention. I get off of my tractor on a hill and I set the brake and leave it running.:thumbsup:
/ HST Creep on Slope #12
yep, they creep....but only till they reach the bottom of the slope....then they usually stop...:)
Well, a tree on the way down would do it too:laughing:
Or the side of your garage:eek:
James K0UA
/ HST Creep on Slope #14
yeap...Mine will creep too... even with the brake on and running. I will usually lower the box scraper, set the brake and dig the bucket into the soil when working on my slopes.
/ HST Creep on Slope #15
I haven't seen a hydrostat tractor or mower that doesn't creep. Once put my ol' JD 425 on a trailer, it was slightly higher in the front than in the back, and forgot to set the park brake before getting off the seat to tie it down. Next thing I knew it was zooming down the ramp of the trailer, thank God no one was standing at the back of the trailer.
/ HST Creep on Slope #16
If it creeps with the brake on somethings not right.
/ HST Creep on Slope #17
Mine doesnt move if the brake is set, engine running or not. I love the brakes on this tractor.
can't help but giggle at that one...knowing no one got hurt of course. A good warning and something to keep aware of.
Have to agree there...might need to adjust the parking brake if it does not hold or could it be possible the HST pedal is out of adjustment a little and engaging??
Being in BC I have some wicked slopes and my parking brake will hold the tractor on these hills w bucket in the air, BH attached and ballast in rear tires. I have to give the pedal a good solid push before locking it but the tractor holds, facing uphill or down hill.
/ HST Creep on Slope #20
agreed, steep slope, engine off, brakes set hard....no roll
That's the way it should be.
Denyo DCA-600SPK 500kW Sound-Attenuated Diesel Generator (A63689)
Denyo DCA-600SPK...
2007 Sterling L9500 Fuel & Lube Y22693 (A62613)
2007 Sterling...
REDDICK OFFSET DITCHER (A63291)
REDDICK OFFSET...
2008 Ford F-250 Ext. Cab Pickup Truck (A61573)
2008 Ford F-250...
14ft Flatbed Truck Body (A59228)
14ft Flatbed Truck...
Lot 602 (A62613)
Lot 602 (A62613)
