Air filter change, wow!
/ Air filter change, wow! #1
jimmyj
Elite Member
Ontario Canada
Allis Chalmers 616 (Two) and a Kioti CK30 HST with loader and backhoe
I must admit with some ebarassment that despite on schedule oil changes, regular greasing and so on I had forgotten about the air filter.
The other day I changed it (at 430 hours:shocked:) and WOW what a difference. The tractor has more power by a noticeable margin. The old filter was just filthy. What a dumb thing to forget about.
If you haven't done it lately, inspect your filter!
Note: Filter was $53.00
/ Air filter change, wow! #2
430 hours without even being cleaned!! I bet it has a bunch more power. CJ
/ Air filter change, wow! #3
I am surprised it didn't overheat. 2 years ago I rented a 45 HP JD and it would overheat every 15 minutes. I took it back the rental shop and they said the overheating was caused due to a dirty air filter and the screen being clogged with sage grass particles. It made huge difference when all was cleaned and changed.
/ Air filter change, wow! #4
When I do my 100 hour engine oil change, everything gets checked over. You have to wait a few minutes for the engine oil to drain, so I might as well put the time to good use. If I was in dusty conditions for a while, I always pull out the air filter and clean it if needed. Nice to see your running strong again. If you are mowing or if you are running in tall grassy/weedy situations, don't forget the screens and take a look at the radiator fins. Also, check the loader mount bolts. The vibration can loosen them unless you have used some lok-tite on them.
/ Air filter change, wow! #5
This "cleaning" of the air filter, I have had zero luck with this and I wonder if it does more harm than good.
Note that you can buy the napa gold equivalent of the Kioti air filter. It is a common filter but still seems expensive.
My filters end up black with dirt and dust. I was getting a bit more black smoke than usual last weekend so I took my leaf blower (used for cleaning the screens) and tried to blow out the air filter from the inside. No improvement and really no dirt blew out. Fitler still black.
/ Air filter change, wow! #6
All these answers and not a single mention of the ridiculous price for the filter. Reminds me of the printer scam. They practically give you the printer and ink is 2k a gallon at the price of those pathetic cartridges. What am I missing? loyalty? Supply and demand? the biddniss as usual mantra. They had the choice to design the housing for the filter to use a commonly available filter. This is why the dealer gives you the `great deal'. It's jist biddniss!
Please see my post below regarding my comments on the price of the filter. I was not very well informed on the subject. i.e. "The reason they are 30-60 bucks each( or even more) is because they are better quality and meant to be cleaned and reinstalled - even washed and reinstalled." This is a quite from Gary's very informative post. Thanks Gary.
__________________
/ Air filter change, wow! #7
Use an air compressor with a blow gun tip. We have one that has a longer tip made from brake line. Works great. Also if you have two air filters, pre cleaner and primary, just blow out the larger onee, the pre-cleaner. Replace the smaller primary air filter.
/ Air filter change, wow! #8
Same here. Filter gets darker with dirt and dust but never seem to get much loose stuff out of it. Some manufacturers advise against high pressure air guns.
/ Air filter change, wow! #9
Man I cant believe what I am reading here. First off, no way a stopped up AIR cleaner would make an engine run hot. If it cant get air, it is going to run rich and rich means cooler. Stopped up radiator from grass seeds, YEP.
When working in dusty conditions like mowing fields or working dirt, the air cleaner should be cleaned daily.
Black filter paper is not a reason to throw away a filter. Check the filter by shining a flash light on it and viewing the opposite side. You can see if it has holes or if it is stopped up. They are made to be cleaned with compressed air, just dont put the tip right against it. The filter is going to be the color of your dirt, if your dust is brown or black, then the filter will be slightly brown or black even when cleaned.
Your owners manual should give you a good work description for cleaning the air cleaner filter with most telling you to tap the filter on a tire to remove the majority of crude in the folds of paper, then use compressed air with the tip 10" or so from the paper. As said, after cleaning check it with a flash light or shop light bulb to make sure it isnt damaged. Unless the external filter is damaged and allows dirt to pass to the inside filter, the internal filter may never need replacing. I have never seen one get dirt or black anything on the internal filter. Most of them can be washed also with soapy water- follow mfg, directions on this though as some may not be washable, but again every one I have ever seen is washable but dont wash it every time it is dusty, there is no need to wash unless they get oily or greasy like from a busted hydraulic hose that sprays oil into the air intake.
I think someone said they blow thru the inside using a leaf blower. I have never tried that so I wont comment on that, but compressed air will clean them and not damage. I have used the same filter on farm tractors for over 5000 hours and never had to replace it. As long as your internal filter is clean each time,you know you exterior one is doing its job. Black smoke from the exhaust when the motor is not lugging is a sign you went too long without cleaning, that and noticeable loss of power.
For those of you that want to replace filters, go ahead and buy new ones every time they look black or dirty. The filter companies love you, but these are not like throw away automotive filters that cost $5 each. The reason they are 30-60 bucks each( or even more) is because they are better quality and meant to be cleaned and reinstalled - even washed and reinstalled.
/ Air filter change, wow! #10
I've never heard of overheating from the air filter ... air compressor is a filters best friend.
This time of year we run the tractors daily in the hay fields and a part of our routine in the evenings is to grease and service them ... every evening the radiators and the air filters get a good blowing out... we also look things over ... a pre flight inspection so to speak ... the eye can see things out of the ordinary that may need attention.
/ Air filter change, wow! #11
Does anyone beside's me use a shop vac on the outside of the filter?.. Seems to work well, and runs no risk of punching a hole thru the paper from using compressed air and getting too close to the paper. I never let them get to the point where there is any caked on dirt in the folds, but If I did I would tap it out as suggested and then vacuum.
James K0UA
/ Air filter change, wow! #13
Sorry, but on a diesel the air charge cools the engine also. Diesels move way more air than a gasser. Most of the larger engines have Pyrometers that monitor the exhaust and a clogged aircleaner will cook a turbo and piston tops in short order if ran for prolonged periods under full power. With our non turbo tractors it is less criticle but if bad enough I could see it cracking pistons under heavy loads. The rest of the post I agree 100% with, I blow all my air filters out from the inside out with a bent tip blowgun, then hit the outside. CJ
/ Air filter change, wow! #14
That may be true that air helps to cool a diesel, cant say as I know enough to dispute that so I wont argue that point. I know for sure that air thru the radiator cools not only a diesel but also gas engines too. NO air thru radiator, no cool on water and steam doesnt cool very well at all. My poiont is that if it cant get air, it isnt going to make full or even partial power. I think it would starve for air and die due to excess fuel that cant burn prior to running hot. I've ran a lot of tractors in dusty conditions to the tune of dumping the cup completely full of dust and the filter pleats completely full when discing all day in dusty conditions so bad halve the time you couldnt see the front of your tractor. Sometimes we would have to servic the air filter at lunch and quitting time to keep them from starving for air. NEVER have I had one run hot. It will start severe black smoke first then loose power. By the way, they all had turbo-chargers also.
If you think about it, the fuel has to burn to produce heat, without air it wont burn as hot and therefore make less power even though the injectors are still pumping in the same amount of fuel. Cool vaporized partially burned fuel is not as hot as fuel burned with sufficient air for complete combustion.
/ Air filter change, wow! #15
I see I posted my comments prematurely, I hadn't seen the post regarding filter cross over numbers or the one on how long the stock ones can last with proper care. I replied to an email notification and I read that one and the ones after it but not those above it. Sorry if anyone was offended. I have a general disregard for corporations anyway. They have gotten way to greedy and devious.
Ron
/ Air filter change, wow! #16
Too many generalizations and non-applicable theories.
The air filter in our Kioti tractors is like a paper automotive filter. The tractors only come with a single filter though you can add a secondary filter, most of us don't. It is not 5$ but neither are automotive filters anymore. The NAPA version of our air filter is about 35$ last time I bought it if I recall correctly.
I have a bigger problem with the cost of that one hydro filter under the floor. A spin on filter that costs like 50$.
/ Air filter change, wow! #17
Highbeam;2853231 I have a bigger problem with the cost of that one hydro filter under the floor. A spin on filter that costs like 50$.[/QUOTE said:
Highbeam, do you or anyone know if there are after market equivalents for that one?
Ron
/ Air filter change, wow! #18
Please let me know where I can find one for my DK35se for $50. I paid 87 to the dealer for that thing.:eek: ouch, let go of my arm!
James K0UA
/ Air filter change, wow! #19
$109 for the hydrostatic filter for the DK50. (The last liar always wins, but sadly, not lying on this one)
/ Air filter change, wow! #20
James K0UA
My OEM filter actually has a Donaldson #, I have not tried to cross it yet but the parts store should be able to. I'll also try to get you the welding info, it hasn't been good the last few days. CJ
2002 International 9200i Truck (A61307)
2002 International...
1989 Corvette Convertible (A61574)
1989 Corvette...
(2) Firestone 18.4-16.1 Tires w/Rims (A64127)
(2) Firestone...
2006 Cadillac GM Superior Coach 6-Door Limousine - Only 21,567 Miles (A63689)
2006 Cadillac GM...
Snap-On Southern Thunder Edition 24-drawer tool box (A63689)
Snap-On Southern...
Caterpillar C18 Industrial Diesel Engine - Serial N8F01120 - Power Unit - Pump Takeout (A63689)
Caterpillar C18...
