3-Point Hitch Position Control Lever vibrates down
/ Position Control Lever vibrates down #1
eds01
Member
Wellington, OH
Kioti DK45HSE
I'm new to the pack - just bought a DK45HSE a couple weeks ago. I've noticed that when the tractor is running at about 2K rpm, the position control lever vibrates down. didn't do this the first week, but now second week its become frequent. Is there an adjustment on this lever to tighten it up?
/ Position Control Lever vibrates down #2
I have a lock down knob that slides on the same slot. See if you got that too.
Yes - I have the lock down knob. I use that if I don't have to have the lower position set at a particular height. More of a problem when I need that knob set and can't keep the implement raised above that.
/ Position Control Lever vibrates down #4
So it wants to viberate up??
No, it vibrates down. I thought the knob was used to set the lower limit for height control - say for box blade grading or mower height. So in my case, if I have the mower on and want to maintain a specific height, I can't raise the mower to move to another place without it dropping back down on its own - just won't stay up. If I move the knob to hold it up, then I have to reset the mower height....seems like the lever ought to stay in one place.
/ Position Control Lever vibrates down #6
I don't know if your 45 is made the same as my CK30hst, but take a look at where the lever connects to the shaft going into the tractor case. Mine has a metal band going around the shaft section that has a bolt to adjust the tightness. Mine was very stiff and I made the adjustment so it does hold but moves somewhat easily.
Thanks Vic. I appreciate the insight. I looked at this and it does appear there are some screw type couplers that can be adjusted. As luck would have it I didn't have the right size wrench but will remedy that tomorrow.
/ Position Control Lever vibrates down #8
A simple fix is to drop the draft control down. I use this when I am riding down the road with a heavy implement (like my flail mower). It stops it from hitting the road...
/ Position Control Lever vibrates down #9
your tractor is out of adjustmenttherew is a sight where you can go ..it explains how to get it to work properly
just google..hoe to adjust hydraulics it will come up..click on adjustments
/ Position Control Lever vibrates down #10
Victor W, you have just answered the question I posed on the end of another similar thread. I have the same tractor and a stiff position control lever & noticed the pinch bolt on the shaft assembly and was wondering about it.
2015 FORD F-150 LARIAT CREW CAB TRUCK (A59823)
2015 FORD F-150...
New/Unused 3 Point Receiver Hitch (A65583)
New/Unused 3 Point...
Iron Bull Golf Cart (A64127)
Iron Bull Golf...
2012 GMC Sierra 1500 4x4 Crew Cab Pickup Truck (A64556)
2012 GMC Sierra...
2018 CHEVROLET SILVERADO 2500HD (A65643)
2018 CHEVROLET...
3pt 6 Row Planter w/Row Markers (A64127)
3pt 6 Row Planter...
