Price Check What's my 2007 CK25 worth
   / What's my 2007 CK25 worth #1
TimC
Candia, NH, USA
2007 Kioti CK25 Gear w/ KL130 Loader
Located in New England (Southern New Hampshire)
2007 CK25 Gear 4x4
KL130B Loader
R4 Tires
Removable Toothbar on the bucket
140ish hours
good overall condition. Hydraulic Fluid and Oil Changed at 100 Hours. Everything works. Bucket is slightly bent, and the tooth bar has one bent tooth.
Little to no rust, only one real New England Winter since I moved up here from the south.
Opinions on what this is worth? We're looking at moving somewhere where I won't need the tractor, and it takes up a lot of space.
I was thinking around $10000 listing price and hoping to end up over $9500. What do you guys think?
   / What's my 2007 CK25 worth #2
New, it'd be about $15K, and yours is practically new. I think $10K is too low.
   / What's my 2007 CK25 worth #3
I traded a '05 Ck30 in '08 w/300+ hrs & got $11K, so I don't think $10K is to far off the mark and might be a bit high.
   / What's my 2007 CK25 worth #4
I think you are in the ball park, but maybe a little high on firm price. I saw a 2008 with 76 hours listed in Tractorhouse for 12,750 and it was posted in Dec 2011 and still there. It was good and clean no dents or rust. The CK 25 was discontinued in favor of the CK27 so that is another strike against it.
   / What's my 2007 CK25 worth #5
Well if you can wait a little, Tier 4 final is going to be implemented for 2013 and that will drive the price up of not only new tractors, but used ones as well.
   / What's my 2007 CK25 worth #6
Wow! That's awefully cheap. I wouldn't sell mine for $10K. Cost too darn much to replace. Maybe next time I'll buy slightly used, if I can get it for $5G's cheaper for mere 140 hours of service.
   / What's my 2007 CK25 worth #7
Gary,
I don't see how it being discontinued is a real strike against it. It was only discontinued due to emissions stanards, not for performance or any other reason. The CK27 is essentially the same engine, just got 2 extra hp or so when it was modified to meet the new standard. There won't be a parts issue as nearly all the parts are the same as the CK's made today.
2014 Ford F-150 Pickup Truck (A56858)
2014 Ford F-150...
Weld on excavator thumb EK1212 (A56435)
Weld on excavator...
2022 New Holland C327 Compact Track Loader (A56435)
2022 New Holland...
gps trailers (A56859)
2026 Quality Steel Dump Trailer (A56858)
2026 Quality Steel...
2015 Peterbilt 367 National Crane NBT55 5-Mast 128ft. 55 Ton Quint Axle Crane Truck (A55973)
2015 Peterbilt 367...
