Loader First Casuality on my new Kioti!
   / First Casuality on my new Kioti! #1
k0ua
Epic Contributor
Branson, Mo.
Kioti DK35se Hydrostat
After I parked the tractor tonite I notice the FEL level rod was out of its guide and bent up. It appears the lower portion of the guide the rod slides in had become unscrewed from the top portion, and allowed the rod to kink up. I have straightened the rod in the shop. But it is too late too dark and raining outside to try to assemble it. It also looks like the lower bracket that is welded to the end of the curl cylinder rod is slightly bent down. I will have to try to straighten that in the daylight. All should be good to go, I am proud of how well I was able to straighten the rod by putting it in a smooth face vise, and carefully bending multiple times and checking for straightness each time. I would probably have noticed it but it was so dark out I was still pushing fill by the tractor lights and really operating the bucket angle by feel not by looking at it. That will teach me!
James K0UA
   / First Casuality on my new Kioti! #2
Common mishap,in ten years I have bent mine several times.In the big picture this is an aw-s**t that is better than most...Mike.
   / First Casuality on my new Kioti! #3
Same thing happened to me clearing snow this winter. Luckily I spotted it right away and was able to straighten the rod and the lower attachment bracket.
I put it on fairly tightly but your post reminds me I should check it again. If it has loosened I will likely put some blue Loctite on it.
I was just thinking the same thing, when I put it back together, I should blue Loctite the threads and tighten the Pixx out of it.
James K0UA
All fixed, I used Locktite, and used an automatic center punch on the joint where the pieces go together to raise a little burr, and painted.. Lets see it come apart now..HA:dance1:
James K0UA
   / First Casuality on my new Kioti! #6
Same thing happened to me. I did remove the rod and guide, built another rod and made an ajustable guide, so whatever implement i'm using i know when it's leveled.:cool:
   / First Casuality on my new Kioti! #7
I too have dislocated the rod numerous times when rolling the bucket to full down.
Do you have any pics of your mod?
   / First Casuality on my new Kioti! #8
Just a beauty mark, that's all
   / First Casuality on my new Kioti! #9
Same thing happened on my new DK45SE the other day, trying it out at the dealer - first time I dumped the bucket, it came apart. Of course I didn't notice it until I curled the bucket back up, instant pretzel! Dealer straightened it out for me and reconnected it all. I'll be seeing him tomorrow, and let him know how many other folks are having the same experience.
   / First Casuality on my new Kioti! #10
Here are some pics of the mod, i did mount it on the left side, since my diverter valve is installed on the right. I did do this on my DK45SEC, put no more tractor=no pics:( It was simple enough to do, took about 20 min.
2025 K0720 UNUSED Metal Farm Driveway Gate Set (A50860)
2025 K0720 UNUSED...
1986 ASPT 30ft S/A Pole Trailer (A49346)
1986 ASPT 30ft S/A...
UNUSED Four-Layer Black Metal Storage Shelf (A50860)
UNUSED Four-Layer...
2007 Ford F-150 Ext. Cab Pickup Truck (A48081)
2007 Ford F-150...
Hyster H155XL Forklift (A48837)
Hyster H155XL...
POLARIS RANGER 4X4 PROSTAR UTV (A51406)
POLARIS RANGER 4X4...
