Loader Hydraulic problem
/ Hydraulic problem #1
xdalex
Eastanollee, Georgia
Kioti CK30
There may already be a thread out there on this but I could not find it. Sorry I am new to this.
I have a CK30 just turned 21 hrs and am experiencing Hyrdraulic problems my FEL and 3pt when trying to lift is very jumpy to and barely lifting it's self up. The fluid level is good.
It lowers itself fine of course. but as soon as I go to raise the FEL the whole tractor is shaking.
Yes I called the dealer and they are gonna pick it up soon but until then I am left with questions that they could or would not answer. Just looking for any ideas or possibilities. Thank you.
/ Hydraulic problem #2
I'll be watching to see what others offer on this. I built a carry - for the 3 point and noticed the same problem yesterday on my DK45 (32 hours), when I was trying to adjust it for level. It does appear to be associated with the downforce lever position.
I'm going to contact the dealer and have him look at that, do the 50 hour (it will have that by Tuesday or Wednesday with what I have tom get done), and install another set of hydraulics on the back to add a top link.
Are you operating anything that requires you to connect/disconnect to the hydraulic system, like a grapple?
/ Hydraulic problem
Thanks for the reply. No I am not disconnecting any lines for anything.
The only thing that I can think of is that maybe it's the pump but that is just a guess.
/ Hydraulic problem #4
Oh NO, the jerkiness has blead into the "other" orange tractors now:confused2: :D
I am not sure what your problem could be. Air in the lines?? Suction side sucking air???
Do keep us posted on what the problem turned out to be when you get it resolved:thumbsup:
/ Hydraulic problem #5
I'm guessing a bad quick disconnect fitting.
Try unplugging and reattaching teh quick disconnects for the FEL. If the fitting is not "passing fluid" correctly, you could get the pump hitting the pressure relief, causing the jumping.
Please keep us infrormed.
/ Hydraulic problem
Thank you I went out and tried that and checked them pretty good but to no avail still the same.
Dealer is on his way to pick it up, I asked him what he thought and he said that it sounded like it was sucking air in there some how or what you said. I asked him to just go ahead and do the 50hr while they figure it out.
When I do find out I will let ya'll know. Thank you for the replies, I am fresh home from Afghanistan getting out in September and just want to grow my little farm and heal my wounds.
/ Hydraulic problem #7
xdalex thank you for your service I hope it all goes your way.
/ Hydraulic problem #8
Are you sure it is not just an adjustment for the 3 point hitch? Maybe I missed it if you already checked but you should try adjusting the little wheel beneath seat front for the speed of the 3 pt lift control
rimshot
OOOOOHH Rah! Thanks for serving in our military and good job.
/ Hydraulic problem #9
My problem was solved thanks to Rimshot -the problem stopped when I adjusted the speed control below the seat. Give it a try xdalex.
/ Hydraulic problem #10
Welcome home and to TBN. Thanks for your service to our country, too.
Did it just start doing the jerkiness thing or has it always been like that?
Did it start with the FEL or the 3PH? What RPMs are you running at when this happens? Have you tried moving the FEL or 3PH with no load, and if so what happens then.
Post back results.
/ Hydraulic problem
@ Coyote machine: I had first started with the FEL then the 3pt and then last when the dealer came to pick it up the power steering was getting jerky.
I had kept the throttle 2100/2200 when I was running the PTO but around 2000/2100 while just using the FEL. I am pretty **** about break in periods and was told to be easy on her the first 50hrs.
I am being schooled and really apperciate everyones imput on here.
When I get her back this week I will let ya'll know the outcome. Thank you:D
/ Hydraulic problem #12
It almost sounds like the hydraulics have been dead ended. Are you sure the remote wasn't on with nothing connected? You could be hitting a relief valve and that's why there's no power left for the FEL and 3pt and it's jerky as it opens and closes as the pressure goes up and down. Not good for your pump if you've been using it this way for an extended period of time.
/ Hydraulic problem
Again thank you everyone that gave there advice. Here is the deal. Somehow or something came up and hit the filter housing not the filter and put a crack in it just above the rear hose/tube. I had never noticed a leak. Dealer said that it was sucking air in there causing my problems. He even brought over the old housing to show me. He said that the leak was real slow to a drip every 20 seconds or so. But enough for air to get in and do what it did.
I have seen the thread on here about protecting that filter and housing and will try to figure something out. Thanks ya'll:thumbsup:
/ Hydraulic problem #14
Glad you got it figured out. I am no kioti expert, but hydraulics are pretty much universal. And what you described sure did sould like sucking air:thumbsup:
/ Hydraulic problem #15
When I had my CK30 stuck in the quicksand I put a plank under the front wheel. Of course it flew back and took my oil filter housing off. Poor little bugger had to sit there for 6 weeks until it dried out enough to dig my way under it to replace it.
/ Hydraulic problem #16
xdalex, Welcome home and thank you for your time, service and personal sacrifices.
I just got to your post and was going to say my CK30 has 29 hours and I have not experienced anything like your issue. Just wanted to let you know I didn't think it was a common issue among our brand/size.
Glad you're back up and running.:thumbsup:
STIHL FS80R POLE SAW (A64276)
STIHL FS80R POLE...
2019 FREIGHTLINER M2 4X2 S/A NON 26FT NON CDL BOX TRUCK (A67148)
2019 FREIGHTLINER...
20 Ton Air/Manual Hydraulic Bottle Jack (A64557)
20 Ton Air/Manual...
REDDICK 300 GALLON SPRAYER (A64278)
REDDICK 300 GALLON...
2016 Dodge Charger Sedan (A64557)
2016 Dodge Charger...
2016 Chevrolet Silverado 3500 Auto Crane Service Crane Truck (A64194)
2016 Chevrolet...
