jinma 220 hyd problems?
/ jinma 220 hyd problems? #1
hazer36
I just purchased a 2004 220 with 77 hrs from original owwner,it had a blown oring in pump,I bought rebuild kit and rebuilt pump,after it was rebuilt it worked fine power steering and 3ph.then I hooked it up to 5 foot finish mower and tried to use it,it would lift it but not hold it up,next thing I know there was a small leak around pump then it was puking from block breathing,it had pumped my hyd fluid into engine.
The org buyer was lifiting trees with it when he blew oring.So the question is whats up with it?:confused:
/ jinma 220 hyd problems? #2
Sounds like two separate problems. Rear lift issue sounds like cylinder bypass. They sell a "rebuild kit" for that too, but it's little more than a big O-ring and a wiper or two. But up front - did you notice hydraulic fluid in the crankcase before or after you "rebuilt pump".
//greg//
first 0f all thanks greg f0r p0sting,have read 0ther 0f y0ur p0st and y0u kn0w y0ur stuff,after taking pump apart I n0ticed the 0ring bl0wn inside pump and just replaced it,hydraulics w0rked f0r 3ph and p0wer steering w0rked well then suddenly puked 0il 0ut 0f breather,s0 cleaned filter under seat, new fluid and 0il and pump kit and here I am again at begining,and this is getting c0stly
Let me try t0 answer y0ur questi0n better,n0 it was n0t leaking fluid int0 crankcase until I repaired 0ring
/ jinma 220 hyd problems? #5
Well if it blew a pump Oring while lifting an impliment, the relief valve in the 3PH control valve may be relieving at too great a pressure which causes the pump shaft seal to fail.
The relief on the 3PH loader valve is probably under a square headed plug on top of the valve body, and is a set of stacked washers that control pre-load on a spring. The one on my 284 was relieving in excess of 3000 PSI when delivered, which caused me to blow out loader control valve O-rings the first outing with a 5' brushhog installed... Used a pressure gauge attached to the quick connect outlet port on my tractor to remove the appropriate number of washers to get the relief pressure down to around 2500 PSI. 3PH not staying up is either valve leaking or blown seals on the 3PH lift piston.
just g0t back fr0m rem0ving guts fr0m QD,added en0ugh fluid t0 get lift up,3ph stayed up with me standing 0n it and I weigh 250lbs,n0 puking till I reved it and lifted it all the way up,I am thinking al0ng the lines y0u are,t00 much pressure building up,where is the relief valve y0u speak 0f?
s0rry ab0ut the zer0s insttead 0f 0's,my keyb0ard is br0ke:laughing:
/ jinma 220 hyd problems? #7
on top of the 3PH control valve there should be what looks like a square headed pipe plug. IF you unscrew that, you should find washers and a spring, and all the way at the bottom the valve plug/stopper that the spring holds in place till bressure below pushes it up to let fluid relieve/bypass into the reservoir.
You will need a pressure gauge in the line between 3PH and pump to evaluate and adjust the relief on the 3PH. IF you have quick connects for a loader, you can get another set and a T fitting to put fairly easilly put a gauge into the circuit. If you have a female rear quick connect, that is also in the circuit, and can be used to measure 3PH lift pressure IF you close the speed reg valve in front of the seat(sends all the pressure to the rear QC port). My 284 has this port, so all I needed was a male QC and I screwed a gauge right into that.
thanks I will l00k at that in am,n0 I d0n't have l0ader but d0 have 1 rear QD 0n rear.I t00k pump 0ff and shaft seal l00ked 0k,it appears as th0ugh it is acting as pressure relief valve at present,will it need replaced?
/ jinma 220 hyd problems? #9
It may, but you won't know that till you can put a gauge on it and actually measure the pressure it is being exposed to. It may indeed be getting way more than rated pressure and relieving, but you won't know if it will work untill you can see if it will hold normal system peak pressure. In my experience though, once a hydraulic seal or O-ring starts leaking, it is done. It could also be that the front pump case has a hairline crack and is deforming causing the leak under the high pressure...
/ jinma 220 hyd problems? #10
Thanks guys I finally g0t her fixed,it was the 3ph RV,first I th0ught I w0uld never get that l00se,when I did the cap with the washer and spring came right 0ut,the plunger was stuck and I used needle n0se pliers t0 get it l00se,
l00kedm t0 have g0tten m0ister in s0meh0w and rusted it shut,cleaned it up
g00d,rem0ved a washer then reassembeled,dr0ve back d0wn pump shaft seal and put pump 0n,and bing0 everthing w0rked well:),used finish m0wer and all went well
T0mmy I b0ught the kit fr0m y0u,I recieved it tue,I may be 0rdering a p0wer steering b00t next,will wait till I need a c0uple 0f things t0 save 0n shipping
c0st,thanks again
/ jinma 220 hyd problems? #14
Glad you got it fixed.
Let me know I will throw in a Keyboard that works, the 0o0's are starting to get too me
Ditto, you supply the keyboard, I'll front the shipping :laughing: .....Mike
/ jinma 220 hyd problems? #15
My 2004 220 jinma 3 pt. will not stay up. I ajusted the stop to lift a little higher, now it will not stay up. I do not know where to begin to fix it, and how hard is it to fix.
/ jinma 220 hyd problems? #16
The search engine is your friend tommy. This issue has surely been discussed several thousand times since Jinmas were introduced to the USA. Yet the Chinese have never fixed the problem at factory level. You need a simple seal kit for the lift cylinder. Inexpensive from a parts perspective, available at most Chinese tractor dealers. Messy job to replace though.
//greg//
/ jinma 220 hyd problems? #17
It would be easy to diagnose by installing a hyd gage in the hyd system.
If you apply flow to the 3pt and it raises to the limits, and the pressure does not build up to the relief pressure, you can almost bet the seals are leaking, and when the lever is in neutral, and the arms fall, that is also an indication that the seals are bad.
There is a slim 5% chance that the 3pt valve is worn and leaking.
/ jinma 220 hyd problems? #18
Just need a seal kit. Not to hard of a job.
Chris
/ jinma 220 hyd problems? #19
a seal job is super easy, it wont take you long at all, call them guys at affordable and they will hook you up and there shipping is like light speed fast, I dont know how they do it,
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
2009 Chevrolet Silverado 2500 Crew Cab Pickup Truck (A64556)
2009 Chevrolet...
2004 Cadillac Eagle Ultimate Hearse, Eagle Coachbuilders, Hearse Collector Special (A63689)
2004 Cadillac...
2016 VOLVO DD25B DOUBLE DRUM ROLLER (A65053)
2016 VOLVO DD25B...
2019 Cadillac Sayers and Scovill 70IN Limo w Only 7729 Miles (A63689)
2019 Cadillac...
2019 KUBOTA SVL75-2 SKID STEER (A65053)
2019 KUBOTA...
