double hunter
Gold Member
- Joined
- Nov 2, 2010
- Messages
- 431
- Tractor
- Ford 1715
Does anyone know where I can get after market brakes shoes for a Ford 1720 tractor.
Just a little FYI, these brakes do run in oil, they are disc brakes, available thru New Holland and aftermarket, takes 3 per side, only adj is the linkage, same disc on several different models,
Just popped the cover off the brakes, this tractor has disc brakes.
Got the parts in today, easiest brake job I ever did, saide the old disc off and slide the new ones on palce, takes longer to scrape off the old gasket than anything else, just slightly expensive,
I should have taken some but this just too easy, theres a splined shaft that the disc slide on, theres also some smooth disc that just go in the housing, smooth disc, splined disc, 3 splines and 3 smooth on each side, should have replaced the smooth disc also, the disc are 85.00 each from NH or 55.00 aftermarket, a little high but worth every penny when your going downhill.
