3-Point Hitch JD M after market 3 pt efficacy
   / JD M after market 3 pt efficacy #1
farmfan
babbitt, mn.
john deeres
Would like to convert my JD M to 3pt capacity with add on kit. Which make works best and what problems accompany such add ons? Any advice from a veteran customizer farmer sincerely appreciated.
   / JD M after market 3 pt efficacy #2
:welcome:
Do you have the touch-o-matic now (I assume yes) ?
Any pics of what you have so we can see what steps you might need next?
   / JD M after market 3 pt efficacy #3
   / JD M after market 3 pt efficacy #4
Worksaver makes a 3 point adapter kit also. Their web site allows you to look at the installation/operation manual for free. I think a 3 point hitch on a JD M is limited in the amount of weight it can safely lift.
:welcome:
Yes, touch-o-matic equipped. I have no pics, just bought '48 M with no plow hanger on belly but want to use light 5 ft. cultivator and small disk between raspberry rows. I see an M3 convert kit and another type on ebay, so want to convert to 3 pt. Original spear equipped, useable M implements are hard to find; thought 3 pt system would be best solution and then could use new small 3pt. cat #1 equipped implements. Hoping for someone with use experience to advise. Wisdom comes with the counsel of many! Por favor &Thanks, Farmfan.
Spirit scooter (A55787)
Spirit scooter...
2017 Ford Explorer SUV (A56859)
2017 Ford Explorer...
Toro Multi Pro 5800 (A55758)
Toro Multi Pro...
New Holland WorkMaster 37 (A53317)
New Holland...
1992 DFI PULL SPREADER (A58375)
1992 DFI PULL...
2016 Toro Groundsmaster 7200 Zero Turn Mower (A54811)
2016 Toro...
